VCDS Coding:
- Select Control Module [Select]
- [03-ABS Brakes]
- Advanced Functions Select [Coding – 07]
- Select [Long Coding Helper]
- Select “Byte 29”
Now it will say 02 which is coding for only ASR OFF via the switch and/or infotainment. You can change it to:
Code = Default Value / Short Press / Press and Hold
01 = ESC & ASR ON / Blank / Blank
02 = ESC & ASR ON / ASR OFF / Blank (Standard for most Golf models.)
03 = ESC & ASR ON / ESC SPORT / Blank
04 = ESC & ASR ON / ESC OFF / Blank
05 = ESC & ASR ON / ASR OFF / ESC OFF
06 = ESC & ASR ON / ESC SPORT / ESC OFF
07 = ESC & ASR ON / ASR OFF / ESC OFF
08 = ESC & ASR ON / ESC SPORT / ESC OFF
09 = ESC & ASR ON / ASR OFF / ESC SPORT (Standard for GTI and R models.)
On some cars Bit values 01, 02, 08, 09 might be the same or interchangeable.
On some cars Bit value 08 might just be XDS OFF.
Part 1 of 4 Vehicle used in this guide UK spec, 2014yr model, Mk7 Golf Estate (GSW), GT (Highline) trim, 1.4lt TSI (140PS) CHPA petrol engine, MQ250 6speed manual gearbox, multi-link rear suspension. Vehicles that this guide is applicable to Any Mk7 Golf which does not have this button fitted...
www.golfmk7.com
