Boost takes a while to get up to specified.How's your boost? Is the actual meeting specified?
Here are the graphs the bumpy line are the actual boost.
Stock tune
Stage 3
Nope ill do it tomorrow. If the compression test check out okay what else do you think it could be?Did you ever do a compression test on this thing?
Update 3/29Did you ever do a compression test on this thing?
The harbor freight compression tester that I got the first time was missing the valves on the glow plug screw in adapters. The second one worked.Have you looked at the intercooler connections. A 22mm combination wrench will come in handy if you ever have to change the tie rod ends.
Good thought but I cleaned it a few weeks ago. Thanks for the suggestion.Just a random thought. does your car still have the snow screen in the intake tube? Maybe it's clogged.
My cam shalf was warm and a few lifters were broken so it was dumping fuel into the turbo.Hi, did you ever figure out what happened and what you did to fix it? I am having the same problem.
