ironmonkey
The free led marker bulbs is that something we have to request when we buy the headlights or are they automatically included with mk4 golf headlights? Also what other bulb is needed when you order the headlights
Thanks! I'll need the switch and harness. Currently have my fogs wired to my low beams in my Depot assemblies but I don't want them ALWAYS on with my HID lows. It'd be interesting to put matching HIDs in the fogs and the lows with these lights...the projectors seem the same size...that'd be a lot of light.Fog light switch, harness, and H3 bulbs.
I'm just bummed it's not winter, I barely use my headlights in the summer!Glad you like them!
Awesome. Thanks, Jeff. I've actually been running the stock headlights this way since 2012 with Philips x-treme bulbs and haven't had any issues, but I don't have opportunities to use the high beams for extended periods of time. I have noticed that my high beams are super bright though.Nothing would happen. With your Golf/Jetta front end, the issue arises in that with the stock headlights, the Golf wiring would cause both filaments to turn on at the same time and get very hot.
With my Jetta headlights, I use a special device that powers the HID under low beam setting, and under high beam it powers HID+Cutoff shield solenoid. With my Golf lights, I don't use that device, and the low beam + powers the HID and the high beam + powers the solenoid. If you ordered a set for your car, I would just wire them up like I do the Golf lights and there would not be any issue whatsoever.
I can do anything with these that I can do with the Golf IV lights. So yes, I don't see why not. They may be able to take the larger 2.5" projectors or they may be too small and need the 1.8" projectors from the Golf IV lights, but one of the two will surely fit in there.Can you do anything with these http://www.ecstuning.com/Volkswagen-Passat_B4--TDI/Lighting/Headlights/ES1884479/ or something similar for us B4 guys…
