tonystdi
Anyone have any thoughts on this tire? I plan on replacing all 4 tires this Saturday.
You got over 100K miles on a set of tires? You have far exceeded the manufacturer's warranty or expectations.The two year old Michelen Primacy's on it now I have over 100,000 miles on them and still have 4-5 10th, 100th or 1000th whatever it is, on them but are developing cracks where the tread meets the side walls. Really disappointed that I have to get rid of them with that much tread wear on them.
I have a set of those hydroedges here that are so dry rotted the tread started to peel away from the tire.. They still have a little bit to go before hitting the wear bars..Very high treadwear rating, replaced, I think the Hydroedge. Hydroedges tended to ride hard and be noisy, but people thought they were fairly grippy. The Passat I bought had a set and I couldn't wait to get them off the car. They do last a long time, will probably dry rot before you wear them out.
So why you would not replace them with the SAME MVX4 Primacy? If it were not for the cracks, you are getting 20,000 miles per 1/32nds in. So if you took them down @ 2.5 to 3/32nd in you would be getting app 140,000 miles !! ??The two year old Michelen Primacy's on it now I have over 100,000 miles on them and still have 4-5 10th, 100th or 1000th whatever it is, on them but are developing cracks where the tread meets the side walls. Really disappointed that I have to get rid of them with that much tread wear on them.
I only sell 91 H Defenders, they are available.I am also getting excellent wear on Michelin Primacy MXV4's on a 2002 Golf TDI. I am at 80,000 miles at apx. 4/32. I suspect these are going to last another 10,000 miles if I run them to the wear bars at 2/32. It's summer in Southern California / Northern Mexico so should be ok to run them down. The treadwear warranty on the Primacy MXV4's was 60,000 miles so I have far exceeded that.
The Defender (or Defender XT at Costco) has a 90,000 mile warranty and a much higher treadwear rating so they should last even longer than the Primacy MXV4's. My only concern with the Defender's is that they are speed rated T vs. H. Sure I am not travelling anywhere near the top speeds for T or H rating but I understand it's generally recommended to get the same or higher speed ratings when replacing tires.
Any thoughts on downgrading on the speed rating?
The Defender looks like an excellent option for a non-performance all purpose tire. In the past I thought that Michelin's were simply overpriced and 'the same' as any old tire. But after owning the Primacy MXV4 I have been educated that not all tires are the same!
I am only seeing the T speed rated version per Michelin's website in size 195/65R15. Part number 10042 or 93957. Do you know what the part number is for the H speed rated version or maybe you are referring to another size?I only sell 91 H Defenders, they are available.
