I will get 80k+ easily out of our Michelins on the B5. However ours was the last year for the 15 inchers (thankfully...longer lasting and better ride). That said, 80k is probably a little on the lower side for me, but I cannot complain as they are quiet, round, and in perfect balance.
Our B5 was cursed with Continentals, which I prompty had swapped at PDI with another B5 that had Michelins.
The 16 inch tires will not wear as well as 15, and likewise 17 not as well as 16, etc. Lower profile, wider tires have a much larger scrub area so they will never last as long as a taller, thinner tire. Laws of physics. I would expect 40 to 60k miles on the 16" B5 tires as pretty standard fare from what I have seen. My friend has an '05 with the 16", and he is well into his second set at 75k.
If you had two worn to wear bars, and two not, then the rotation schedule needs to be stepped up, or the tire inflation needs to be examined. They should all wear dead even.
Also, the 'alignment' requires a special fixture, VAG 1920 IIRC. It is a $700 tool that every VW/Audi dealer will have, and virtually NO "tire chain" will have, much less know how to use. It is IMPOSSIBLE to correctly align a B5 (and the bigger Audis) without this fixture. If you had your B5 aligned by someone that does not have this tool, your alignment is NOT correct. Period.
Yes, I have made the investment in this tool to properly align these cars, and I know how to use it and make the car's alignment correct.
