tdmsurfguy
While doing a oil change and snooping around I found some metal shaving in the intake pipe around the Evap trap:
I’m also getting a a weird screaming noise from 2000-2400RPM when the turbo should be spooling up under load. I need to check to see if all the piping coming into/out of the turbo aren’t broke but that wouldn’t explain the metal in the intake. If the turbo is failing would it send metal that far up? BTW my car is a 2002 with 240k miles on it completely stock. Thanks for any help
