Metal in the Intercooler (with pictures)
Engine toast?
  • Yes :(
    Votes: 0 0.0%
  • Maybe
    Votes: 0 0.0%
  • Total voters
    1
danmin
DFW
2014 Passat 2.0 TDI @ 180k
Turbo blew and I’m replacing that plus my DMF, oil pump hex shaft, mounts, timing service and the upgraded oil cooler all in one go.
I’ve got my car in pieces right now about to pull the engine and I eventually pulled the elbow connecting the turbo to the intercooler at the front. Found metal pieces and a pool of oil in the bottom of the intercooler. Also part of a big O-Ring.
I turned the car off as soon as I heard a “pop” come from the engine bay. Engine ran for maybe 2 seconds after the fact before I turned it off. I’m worried metal got into the engine from the turbo going.
What are the odds of metal bits harming the engine? What would be the result if so. Is a tear-down warranted? I was hoping I wouldn’t have to crack open the engine… Also what could possibly be the rubber o-ring I found?
With so many CKRA owners having blown turbos- I doubt each victim had to replace an engine or tear apart their intakes to clean them of metal. Just hoping for the best and preparing for the worst I suppose. I don’t want to get the car in running condition after all this just to shred the new turbo or rio the pistons and valves up.
Ackilys
Ontario
‘09 Jetta dsg, ‘11 jetta 6spd, ‘13 passat dsg
I’m told compression test it. Should be 550 psi if I’m remember correctly?
Tom in PT
Twilight Zone, WA State
I think its unlikely the metal got into the engine if you shut it off so quickly. But I would completely clean out that intercooler - who knows whats up there, (I know, its obvious). That O ring might be from a oil seal in the turbo that blew up.
2004LB7
California
2006 Jetta
Intercoolers are pretty good at filtering out particles. How does the outlet side of the intercooler and intake manifold look? Any signs of metal?
danmin
DFW
Just put the intercooler back on after doing a few other things with the motor removed. Cleaned it out pretty good and ran a hose through it (backwards) for 2 hours to make sure there wasn’t anything in it. I didn’t see anything come out when cleaning it. Just a lot of oil and oily sludge. I didn’t go through the sludge but I imagine that captured some particles.
I took a borescope and looked in the manifold but it was way too dirty with black buildup to see anything. I checked the exhaust valves since the turbo is off and I saw some “glitter” but not a lot and the exhaust valve edges weren’t visibly damaged. I’m gonna run it when the new turbo comes in and hope for the best
740GLE
NH
whats that in the DMF DSG input shaft? looks almost like needle roller bearings all loosey goosey .
p.e.fletcher
Tallahassee, FL
2013 Passat TDI SE/2011 Golf TDI
dang hopefully no internal damage to the intercooler itself because it’s water to air can leak coolant and blast it into your manifold. did you happen to pressure test it?
danmin
DFW
I didn’t exactly do a pressure test but I cleaned it out both through the coolant passages and the airway and didn’t see any water/bubbles collecting anywhere it shouldn’t have
