Slou92
I've researched this topic and I found mixed opinions. Most posts I've found are older and I'm wondering if there is more experience now.
2014 TDI, 40k fuel filter change. Just like at 20k, there was some metal flakes in the filter housing. They do stick to a magnet. I called the dealer at 20k to document and the service manager said that is normal and they usually stop finding them at the 60 or 80k filter change. I installed the 2micron kits at 30k and there was no contamination found under the metering valve.
There is less metal this time, but I've had the 2micron kit for the last 10k.
How concerned should I be that the HPFP has an impending failure? For those that work on these cars, is this normal? Is it possible that these flakes are from the lift pump or aux pump?
