torahtom
Connector and plastic box melted on the small Allen bolt and lug in the top right corner of the module where the red hot lead comes in. Took out the control box and used a dremmel bit to remove melted plastic. Lug was about 1 inch away from its hole. Siliconed it back in place. Got so hot it melted the cover and blue out main power relay #109 in fuse box. Tried to start it with a tow but no fuel getting to engine. All lights on dash except the oil and battery light stopped lighting up. No speedometer either. Thought the ECU was fried too. Took out the ECU and inspected it and no burned parts of circuit board. Put ECU back in. Checked battery ground for both positive and negative under the battery. Put a new 109 power relay in and now glow plug and all lights come on on the dash when turning the ignition on.
Does anyone know where else to start looking for a short?
Can the box be reused? Or does anyone have a glow plug control module box. Part # is 191 911 261 b
