I just asked the service department, the fluid is changed, but not the filter. At least I am due for the fluid change, so I get a free one this round!The trans filter is not changed in the campaign. I changed it myself when I got the car back.
Yep, you get 5 1/2 liters of trans fluid, I've seen the bulletin. You're better off doing the filter yorself, so you can see if the dealer screwed anything up.I just asked the service department, the fluid is changed, but not the filter. At least I am due for the fluid change, so I get a free one this round!
Picked up the car this morning after getting the MU replaced. So far, so good!I've had my 2010 Golf TDI into the dealer a few times for stalling & lurching when starting from a stop. They've replaced a few filters (EGR, etc.) but it's never really solved the problems. I just got the call from them saying that they have now concluded I need a new Mechatronic Unit to solve the problems. Of course no MUs can be found in the northeast, so I get to wait on one, but I'm really hoping I get the resultes that you described after the MY gets installed. Thank God for the warranty.
Of course my build date says "12/2008"The potentially bad MUs were installed up to 12/15/08. The information was in the bulletin.
Did I miss the link to the exact bullitin? Can anyone point me that way?Of course my build date says "12/2008"
How the hell do I know if it was before or after 12/15/08. My VIN didn't pop up any recall on the VW website, and I don't know for certain that I notice any of the signs, but ***! Will I be eligible to have it replaced or not?
The company will also extend the transmission warranty of all vehicles involved to 10-years, 100,000 miles. The extended warranty will also be transferable.Did I miss the link to the exact bullitin? Can anyone point me that way?
You could drive around in sport mode, it has the effect you are looking for, although the shift points might not be what you want for everyday use.Well, looks like I'm not affected based on that VIN range. Also, my build date is 09/09. It would be nice to at least get a software update to raise the shift points!
I'll have to give Manual Mode a try to see how that feels in rush hour, heading to DC on Friday. Fortunately the unit is being replaced in about 2 weeks.Nope. There's no happy medium. I tend to just put it into manual mode when I don't want the engine to lug and the DSG to shift so early. I can only assume/hope the engineers designed it to protect itself appropriately.
which brands do you fill with?Yes, 93K problem free miles, and NO additives of any kind.
Wes
I just had my Mechatronic Unit replaced today, and my results seemed a bit different. I've only driven about 50 miles on it so far, but this is my initial impression:Here's what I've noticed in the last few days that has changed. I would assume what I am now experiencing is likely the "standard" that is already installed on more recently delivered Jetta's with DSG.
1. The digital display now indicates the gear that is currently being used.
2. The shifts are slower and much "softer" than before.
3. The RPM's for each shift are higher than before.
4. The car won't shift into fith until 35 mph, and sixth at 45 mph.
5. The car used to stay in second gear unless I came to a complete stop. It now would shift to first even with slow rolling stops.
6. Upon starting from a complete stop, there is a slight slippage (very slight) whereas before it was grab and go.
7. Upon starting from a complete stop, if you remove your foot from the brake, but NOT apply throttle, it used to grab and roll. Now it grabs and released, grabs and releases, and usually on the third nudge, it will grab and lock in.
Overall the tranny is now generally smoother than before. I question if the higher rpm's will have a negative impact on mileage. Prior to this reprogramming, the car would shift into 6th gear around 35 mph. Now, unless you manually shift, it won't even consider it until 45 mph, and quickly shifts back into 5th once you drop below 45 and apply any throttle whatsoever.
Is this what most of you find to be consistent with your DSG???
Wes
Well you are describing how my old unit shifted. So, when did your old unit upshift to 5th and 6th? Are you sure the rpms with the new unit are lower than with the old unit before when shifting (point 3) ? If that's true, it implies that your old unit upshifted to 5th and 6th at even lower mph than 30 and 40 mph. That would be hard to believe as the engine will be lugging significantly.I just had my Mechatronic Unit replaced today, and my results seemed a bit different. I've only driven about 50 miles on it so far, but this is my initial impression:
1. Same.
2. Quicker shifts, feels softer.
3. RPM are lower than before when shifting.
4. 5th at 30, 6th at 40 with gentle acceleration.
5. Kept in 2nd until less than 5 MPH. Downshifts were a lot smoother than before.
6&7. Opposite feeling.
Overall, I agree that it feels smoother when shifting. Before, it almost felt like a newbie driving a manual (especially when starting out from a stop), and now it feels as if it has mastered the technique.
The biggest improvement I've noticed is that it takes off with no stuttering as it occasionally did before.
For the most part, I have been driving with gentle acceleration so far."Well you are describing how my old unit shifted. So, when did your old unit upshift to 5th and 6th? Are you sure the rpms with the new unit are lower than with the old unit before when shifting (point 3) ? If that's true, it implies that your old unit upshifted to 5th and 6th at even lower mph than 30 and 40 mph. That would be hard to believe as the engine will be lugging significantly."
