JohnnyRad
2000 Golf GLS TDI (115k miles)
Hi All, I'm not sure what to do. My mechanic (on trusted list) informed me Thursday that my turbo needs to be replaced ($1100 parts $400 labor). I brought the car in 3 weeks ago because the Ck Engine light came on. At that time the mechanic said the following:
"code 19586 - references; no procedures to diagnose;
VW does not refer to that code; but has come up
in other diesels...refers back to EGR system that it
has exceeded its limit; EGR ports look good; EGR built
into body...put cleaner in for fuel injectors;
EGR valvel gets stuck every once in a while"
So during the past couple weeks the car has been inconsistently sluggish. Both with acceleration and maintaining speed. I say inconsistent because at times it runs fine with normal accerlation and driving speed. Other times I'll be driving up a incline on the turnpike and the car looses speed despite having accelerator to the floor. (MAF was replaced 4 yrs ago by VW due to power loss)
The mechanic said something about a vacuum/pressure issue. I didn't ask a lot of questions. After reading some posts from owners with similar problems I'm not convinced it's the turbo. Can you recommend specific questions to ask to help me determine if this mechanic is making a good recommendation? Any help is appreciated. Thank you!
