Anybody who knows a lot more about the CCM than I do have any thoughts on this:
http://www.passatworld.com/forums/showpost.php?p=1461700&postcount=1
{Edit by VW Derf to remove links to pirated software}Scatha at PassatWorld said:Solution: rollup/rolldown windows by keyfob without alientech/autowindow
Hi!
I can't find anything about it here on the forums so I decided to post this information here. A while ago some clever geniuses in germany discovered that you can modify the software of the central convinience control module so that it works like it does in Audi cars for ages and it does in the newer VW.
Press and hold the open button on your keyfob and the windows roll down
Press and hold the close button on your keyfob and the windows roll up
What do you need to do to get this to work?
1) a laptop or pc
2) a serial vag-com cable. Not all of them work for this. ProChip and orignal Rosstech interfaces are known to work in most cases
3) a pretty old dos only software called VDC Pro
I found two links to the software on it on the internet:
{COPYRIGHTED MATERIAL}
You can't do this from any windows version (Dos only!), with any USB interface or with VAG-COM or a VW 1551 tester.
Use the following procedure to reprogram the module
1. start vdc
2. connect to central convenience (46)
3. start login procedure (11)
4. use the code 19283
5. read serial eeprom (26)
Find the list of known values further down this post. Write down the original values at and continue.
6. write serial eeprom (27)
Enter the memory address and value mentioned in the list down below.
Do this for all addresses mentioned
7. end output (06)
Now exit your car and lock it. When you now open your car with the keyfob and hold the button the windows should start to roll down and stop when you lift your finger.
This works for all VW/Seat/Skoda cars that use the same type control module. Passat B5, B5.5, Golf Mk IV, Seat Leon, Jetta, Bora...
The following codes have been collected on different boards in Germany for the listed modules:
1J0 959 799 AH (any index) and 1J0 959 799 S 03B
1J0 959 799 J 00ECode:Memory Address / old value / new value 04283 / 8 / 2 04289 / 8 / 2 08628 / 242 / 246 driver side front window 12724 / 250 / 254 passenger side front window 16280 / 250 / 254 driver side rear window 20916 / 242 / 246 passenger side rear window
1C0 959 799 A (any index) and 1C0 959 799 B (any index) for Variant/WagonCode:Memory Address / old value / new value 04286 / 8 / 2 04291 / 8 / 2 04296 / 8 / 2 08628 / 242 / 246 driver side front window 12724 / 250 / 254 passenger side front window 16280 / 250 / 254 driver side rear window 20916 / 242 / 246 passenger side rear window
1C0 959 799 A (any index) and 1C0 959 799 B (any index) for Limousine/SedanCode:Memory Address / old value / new value 04361 / 75 / 67 04362 / 75 / 67 04363 / 75 / 67
If you find any more codes/version/control modules where this works please post the codes here.Code:Memory Address / old value / new value 04361 / 74 / 66 04362 / 74 / 66 04363 / 74 / 66
If it doesn't work just put your old values back in there and no harm is done.
