MaxiTrip TP100 software update ver1.2
torqueluvr
PICKERING, ONTARIO,CANADA
2004 tdi sport edition GLS,2003 Silver Jetta 1.8T GLS
MaxiTrip TP100 software update ver1.2 Anybody?
Hello All
Just got an ECL/DTC on the way home driving on the highway,pulled off at next exit used a blue tooth dongle OBD2 using Torque app with my blackberry Z10 and found a code to do with coolant sensor issue,coolant temp below sensor range ?P0128?
Coolant level was okay and temp gauge in car was normal as always...oil level is good,engine sounds normal..
Then I remembered that I had purchased a MaxiTrip a few years back,opened it up installed software,connected it up all for the very first time...shows connected to pc. ver 1.1...
I set it up in my 04 TDI Jetta,found the same code on the Maxi,was able to clear it,just in case it was a momentary sensor glitch,drove a few kms later in the evening,no ECL/DTC came up ??
Then I did a bit of snooping around and found that there is an update to ver 1.2 which is suppose to correct a few errors found in the original software.
Good luck finding the .bin file anywhere all links have expired..."404 no longer available".
Any chance one of our resourceful members still has this ancient file somewhere...?
Thanks as always..
Enjoy your summer
