MattMan's 2003 Jetta Wagon 5 Speed
_MattMan
Lancaster, Ohio
03 Jetta GLS Wagon 5sp
Purchased with a dead motor, with the help of TDIClub member Growler, replacement motor is coming from Franko6 and misc. parts from BoraParts.
Project details to come.
_MattMan
Lancaster, Ohio
Engine Hoist attached & Motor out
01/20/2012
Preparing to pull dead motor
Motor Out
Empty Motor Compartment
ymz
Between Toronto & Montreal
2003 Jetta TDI Wagon, 2003 Jetta TDI Wagon
So you guys took the engine out the top... I always thought it's less trouble out the bottom... but what do I know...
Yuri
Growler
Got Soot Vendor
Millersport, Ohio
just had to remove the hood, and it popped right out, notice the load leveler on the cherry picker, allows you to lower the trans/raise the engine as you pull it out to swing the pumpkin around the brake booster as you come out the top.
easy peasy :D
Growler
Got Soot Vendor
Millersport, Ohio
Yes, that is me on any given saturday,... I have gotten lots of good use out of my dickies :) and as you can see, I was wearing my TDIClub knit hat that morning before i got too warm.. hence the lovely hairdo. :D
Ant yes, the other picture is me when I am not getting durty working on cars..
_MattMan
Lancaster, Ohio
Week #2 - It's like Christmas !!!
Parts have arrived from BoraParts, The Panzer Deluxe Skid Plate has arrived from DieselGeek.
This week we plan on taking the transmission off and salvaging what is needed to install on the replacement long block engine coming from Franko6. (Frank's VW TDI's, LLC).
I hope to post Pictures of Christmas and tear down when time permits.
Growler
Got Soot Vendor
Millersport, Ohio
we got together last night and he took some photos of the parts we have received so far. we also stripped the old engine and removed the transmission.
upon pulling the injectors out, I noticed that I was not the first one to pull these injectors out of the car...
What is wrong with this picture..
greengeeker
Cambridge, MN
2002 Jetta GLS
With half of the injector holes shrouded like that I wonder what that would have done for smoke, FE, etc? Any cylinder damage?
Growler
Got Soot Vendor
Millersport, Ohio
don't know about cylinder damage. the engine is getting replaced with a whole new longblock, and with as bad as the #1 piston is beat up, the crank is essentially seized in the bore, I didnt even have to use the flywheel holding tool to break loose the flywheel bolts last night.. that should tell you how seized it is.
Growler
Got Soot Vendor
Millersport, Ohio
Silly boy... didn't you know that the first lesson in mekaniks skool is: "if one sealing washer is good, two are better" ??
Yuri
that must be why I don't do that.. I never went to mechanics school.
_MattMan
Lancaster, Ohio
Old Engine Prep & Parts Cleaning
Growler Disassembling old Engine
Bracket - Before Cleaning
Bracket - After Cleaning
Transmission Before Cleaning
Transmission After Cleaning
Growler
Got Soot Vendor
Millersport, Ohio
Just got word that a rather large and heavy box/crate has shown up for us to go get...
hijinx will ensue tonight and continue on Wednesday!
_MattMan
Lancaster, Ohio
Day 4 - Engine Arrives
Engine in the box
Growler opening the box
Awww, what's in here ?
Rebuilt Engine from Frank's VW TDI's, LLC
Misc Parts
See, VW's are part of the NASCAR Family
_MattMan
Lancaster, Ohio
Day 5 - Engine Assembly
Engine on Stand
Accessory Bracket and Oil Cooler / Filter Housing
Turbo Installed
21# Single_Mass FlyWheel / Clutch / Pressure Plate
Transmission Installed
Finishing Touches on Day 5 Engine Assembly
Growler
Got Soot Vendor
Millersport, Ohio
I say it was a pretty productive evening.
Looking forward to friday and the reinstall into the chassis/First start :D
TonyJetta
Tucson, Az
'15 Jetta TDI SE / '06 Jetta TDI DSG Pkg0 / '96 Passat TDI
Nice progress! Glad to see a worthy car soon to be back on the road!
Tony
Growler
Got Soot Vendor
Millersport, Ohio
Aaaand after a 14 hour day yesterday... She runs :D and she runs nicely. Timing was EXACTLY in the middle the first time upon assembly and initial start.
HOWEVER.. today we need to do a few things.
1. Replace the alternator. It doesnt charge the battery. and we have a code for it as well.
2. Ziptie/solidly mount the side to side shift cable to the bracket on the transmission. its been broken and doesnt hold itself in place so we cannot find reverse. (Anyone have a shifter box and cables for sale?)
3. Reinstall the front bumper cover (had to remove it to get the hose clamp behind the headlight installed)
4. reinstall the hood.
5. Change the oil with the second round of Joe Gibbs BR after the initial 20 minute break in period from last night.
oh ya, one snafu we had.. make sure that BOTH of the two hoses that click into the firewall are actually clicked in place. those hoses will leak a LOT of coolant quickly and make it very difficult to bleed the coolant system. :D oopsie.
overall, it went very easily for my first complete engine replacement.
rackaracka
Monroe, NJ
Great work Aaron! That intercooler coupling behind the headlight can be a bear! Thank god for remote cable operated clamp pliers. No video?
TonyJetta
Tucson, Az
Congratulations!
Glad to hear another TDI is back on the road! Well, very soon to be.
Tony
_MattMan
Lancaster, Ohio
Final Assembly
The Help (Oliver & Aaron Shaw)
Almost There
Engine Being Lifted
Wagon Awaiting
_MattMan
Lancaster, Ohio
Engine Install
Engine Going in
Some Disassembly Required
Ok, Let's try again - Tight Fit
It's In !! Lets start hooking things up !!
Growler Installing Fuel Injectors
Engine Almost ready to start
