master cylinder brake booster question
nissansentra
Indianapolis, IN
2005 Vw jetta pd1.9l
Hello All,
2004 vw jetta tdi gls manual transmission
I am leaking fluid between the master and brake booster. my question is can I just replace the oring behind the master cylinder and everything will be good? If this seal brakes then will brake fluid leak into brake booster thereby needing brake booster as well? Im trying to do it as cheap as possible, but also to do it right the first time.
THANKS!
Jordan
Can't say I have ever seen that before, but yes you can get just the master cylinder for the brakes. So I suppose if that is all that is wrong you could do it that way.
The ESP cars use a different one that those without.
nissansentra
Indianapolis, IN
so the way the master and brake booster mate I wont have a problem in the future with a corroded brake booster diaphragm right? Sorry to be redundant just dont want to waste money! thanks for your help!
Dieselmonkey02
Edinburg, Pa
02 jetta
As long as the booster didn't take on a lot of brake fluid I think you'd be ok. Brake fluid eats paint faster than just about anything so keep the fluid cleaned up.
nissansentra
Indianapolis, IN
roger that. Funny thing is it stopped leaking all of the sudden? weird huh? it does this occasionally. I will go ahead and order a new master. Thanks for all of your help
Jordan
Chris
Bloomfield Hills, Michigan, USA
If fluid is leaking out there you may have a booster full of fluid (or actually about half full).
The booster can function this way but at reduced boost.
The seal between master cylinder and booster is supposed to seal air from leaking into the booster.
You'll want to remove the booster from the vehicle so you can dump it out, when the time comes.
03TDICommuter
So. Cal
01' NB, 5spd
What he said.
One thing I would say though is that brake fluid is hydroscopic. It will absorb moisture and you're going to eventually rust your booster from the inside out. It eating the paint or coating away on the inside won't help.
jimbote
Tacoma 4x4 converted to TDI
"hygroscopic" not "hydroscopic" ... brake fluid is designed to absorb moisture to prevent brake lines and components from rusting by suspending water molecules in solution rather than it settling to low points in the system
03TDICommuter
So. Cal
01' NB, 5spd
Thanks for the correction. So not a concern about rusting from the inside of the booster?
Ol'Rattler
PNA
2006 BRM Jetta
Yes it's a concern. Brake fluid absorbs water out of the air. The humidity in the air is absorbed anytime brake fluid is present that is not in a sealed system or a sealed container, such as when there is brake fluid inside the booster.
Inside the cabin or outside the cabin does not matter.
BobnOH
not-a-mechanic
central Ohio
New Beetle 2003 manual
If the fluid is into the booster, wouldn't it end up in the vacuum system? Would it be possible to purge/clean it using the vacuum fitting?
jimbote
yes, you would need to suck as much out as you can first followed by a safe solvent, rinse repeat ... but once down to mostly solvent the vacuum should boil the remainder away... i've actually thought about using the vacuum pump to evacuate the AC system after repairs but i already have an AC vacuum pump
Chris
I'm going to guess that the level of vacuum that the pump in these vehicles provides won't be nearly as effective as an AC vacuum pump.
As to the risk of ingestion, the port is up near the top of the booster housing. By the time the brake fluid reached that level you'd be experiencing a near total loss of boost (hard pedal).
AnotherPerson
New Orleans
1999 Beetle
My original booster had the diaphragm eaten up by brake fluid causing a vacuum leak. If you pull the booster just replace it. You can get the new upgraded booster setup with upgraded master from vw for around $250.
Ol'Rattler
PNA
2006 BRM Jetta
I'd say don't buy it from VW. go to ID Parts, Bora parts etc for OE/OEM parts for less money.
