AnotherPerson
Trying to judge a couple things on my car and this is kinda a 2 part question. When a map sensor is failing has anyone ever had it report higher boost than it's getting?
Second part, if the map sensor is saying to the ecu I'm getting 20lb of boost does the ecu fuel for 20lb of boost? I know newer cars can adjust but didn't know if the alh based fueling on sensors or if it was just set throttle position and rpm maps for fuel.
