pugchi3
I have a 2013 Passat TDI and recently had an check engine light come on and code P0113 when scanned. Map sensor giving 2 different inlet air temps one normal and the other a negative number. Replaced the MAP and MAF sensors. All engine codes and warning lights went away for about 2 months. Recently went into town to fill up with fuel and upon leaving fuel island I had a return of the check engine light and the engine malfunction light also came in. I limped home as the vehicle had limited power and was able to finally get it up to 60mph. Again had my neighbor mechanic scan the car and the P0113 code had come back in. The sensor was again showing 2 different temps as before. I replaced the MAP sensor again and everything was good for 1 day to work and back. The engine malfunction code came back in again and I had to switch out vehicles for work. Something is going on and any help would be much appreciated. I will scan the car again tomorrow.
