NECRO RAISE !!!-
Wanted to bring this back up because I encountered this issue but had some different results in sourcing a repair option
We have an 02 golf 4 door - driver's door window regulator clips broke and it is also a manual window.
jimellisvwparts - a personal favorite site of mine, world impex, ecs, my local KOI - all said the same thing. A repair kit for a mechanical window regulator does not exist. You have to buy a complete new regulator with the metal panel attached (in my case 1J4837729BK for drivers front)
I didn't have the time to do this myself so I took it to a local VW shop who has been good to me and they tried to use the repair kit that has 4 clips and cables. It didn't work. cables were different and the clips used on the mechanical side were different - I visually had to inspect it myself to believe it.
It doesn't make any sense to me because why would they use different set-ups on the interior of the regulator? the mechanical set up should be the exact same as a power set up just minus the motor... So you would think. But if you take a look at this image
http://www.jimellisvwparts.com/showAssembly.aspx?ukey_product=5214944&ukey_assembly=743414
you will see it points to two different set ups for the power and mechanical regulators. however the rails and regulator parts appear identical.
I still don't believe it as I'm typing this.
cheapest fix? car-part.com or your local pull n save.
quickest? best I can see if buying an entire regulator
If anyone can prove to me I'm wrong I would love to hear it, because I'm still dumbfounded that this is my only option to repair these clips.
