Malone tune question
Schoust
Litchfield County
00 Jetta Alh 5spd
Hey Guys
I purchased an 03 that was in an accident (total). I bought it for the performance stuff the guy had on it. The ecu has been tuned by Molone.
Can the ecu just be swapped? My car is an 00 tried it car starts and dies. No immobilizer issue according to the dash light. Any idea how I can run this tune?
GlowBugTDI
Cambridge, MN
Hey Guys
Do the ecu letter codes match? The codes are probably different being they are from 2 different model ecu's. 00 and 03 ecu have different files, and I'm not sure you can mix them.
Schoust
Litchfield County
00 Jetta Alh 5spd
Yea I seriously doubt they match. My kid insisted it would work. That's why you never listen to your kid!
My trucks tuner is Vin locked and can only be used on another truck once the tune is pulled. I figured there would be something different. Is there a way to get it changed to my code?
turbodieseldyke
Free Mustache Rides
98 jetta
Run the software found below to see if the immo is truly not the problem. Starts + Immediately Dies sounds like the immo is doing its job.
Schoust
Litchfield County
00 Jetta Alh 5spd
Yes the Immo. comes on and shuts off when the engine starts as it has always done. Then it just shuts down as if something was shutting it off..
I attempted to contact Malone and set up an account but for some reason It won't except my info to move forward.. This car was an auto converted to a stick if that makes any difference. Also egr was deleted and my car still has it.
Is this something that can cause an issue? The egr flap. Isn't shutting? Not sure but maybe the fuel is shutting down?
