Hi all! I am planning some major maintenance for my 2002 Jetta TDI (168,000 miles) in January 2008. I am looking for a bit of input from the TDI experts out there. I know for sure that I need a new timing belt. I was also advised to replace the serpentine belt and the lifters at the same time. After doing research online, I also saw that when you change your timing belt, you should also replace the water pump, tensioner, and v-belt.
So, this brings my list so far to...
timing belt
water pump
serpentine belt
lifters
tensioner
v-belt
Anything else anyone can recommend? I am trying to pre-plan for the sake of money, but also good maintenance. I would hate to not replace something that is harder to fix once something else is done, ie: not changing the lifters when the timing belt is done. Any advice you all have is great! Thanks!
timing belt
water pump
serpentine belt
lifters
tensioner
v-belt
