Maintenance Schedule for 3.0 TDI
kraftwerkturbo
Brighton, MI
2005 Golf 1.9 TDI auto
I have 2012 Q7 (155k) and 2013 Cayenne (210K).
Aside from oil and filters, no other documented maintenance.
What should I schedule to do?
gforce1108
Newburgh, NY
04 Jetta GLS BEW, 14 Audi A7 V6 TDI, 13 Porsche Cayenne V6 TDI
Manufacturers consider most of the other items "lifetime" (BS). All fluids should be changed - transmission, transfer and F/R differentials. You have 2 Aisin transmissions.. At least every 100k (ZF says something like 50-70k but I haven't researched the Aisin yet). Sooner is better. Everything else that I can think of is as-needed. Keep an eye on timing chain stretch (VCDS on the Q7, unfortunately it doesn't work on the Cayenne)
kraftwerkturbo
Brighton, MI
What measuring block in VCDS shows timing chain stretch for the 2012 Q7?
Jayhawk94
Denver, CO
2013 Q7
I’m changing oil/fuel/air/cabin air filters more often than recommended but here’s my personal schedule. 2013 Q7 CNRB engine
Less than qM
Tire pressure q2wk
Monthly or q1000mi
Oil level
Q5k
Oil & filter - VW 507 00 spec, 5W-40, 5W-30 or 0W-40
Q10k Berg recommended (Audi recommended q20k)
Fuel filter
Annual or q5k
Rotate tires
Annual Or q10k
Std. Maint stop
Annual
Wipers Bosch Icon 26OE (right), 24OE (left) H772 (rear)
Check coolant for temp rating and contamination
q20k
Engine air and cabin filters
Biannual or q20k
Major maint - plenum panel check - remove & clean, lube door hinges/straps, sunroof clean & lube
Biannual
Brake fluid - check appearance and moisture content (<2%)
Triannual
Battery
Engine coolant - G12++ or G13 (G12+ in a pinch)
Q50k
Power steering fluid - mainly do so once dirty
Q60k
ATF oil & filter, pan gasket & filter, Aux gear box oil, front/rear differential oil
  • ZF recommends q80-100k km
  • Prestige Audi mechanic said could do at the 55k stop
  • 2007 A6 trans manuf. says to change at 50-60k mi
  • MB recommends ATF flush & filter at 40k
Q100k
Water pump
Serpentine belt
Check timing chain guides?
Q150k?
Timing chain
