Nevada_TDI
I have heard one of the tune providers puts into the tune to prevent the turbo from spinning down during shifting. Has anyone heard of this? Would it make that much actual difference reducing RPM loss between quick shifts?
Exhaust is always going through the turbo if the engine is onSo the turbo can spin without exhaust going through it?
This is why they call it power unit, used to be KERS when they only harvested electricity conventional way from the drive motor, now they harvest from the turbo to recharge faster, and I guess keep the boost up. F1 tech is just silly, but some of it does trickle down to us plebsFWIW, this is actually done with high performance F1 and other extreem type race engines. they use a massive electric motor bewteen the hot and cold side and use batteries to power it to make boost at whatever the tunner wants at 100% of the time if needed, downshifting can actually charge the batteries.
F1 definitely harvesting power from the turbo shaft now, it might be short lived but AFAIK currentKERS systems work by being driven from the gearbox from rear axle decel loads that are stored in batteries (to be released into a motor driving the crankshaft) or flywheel (released mechanically back to the rear/drive axle). I am sure the engine management system plays with the turbo a lot, and it IS possible they now use e-turbos (not sure, don't follow F1 any more).
That bang-bang can be achieved on a NA car with a tune, I think they call it "crackle and pop", you basically pay money to make your car sound like **** every time you lift...You need Anti Lag!!! But then again this a VW TDI not a Rally Car. Try a ball bearing turbo.
