Mr Wizard
Hey Guys,
Was going to put the crank in my engine and make some plastigage checks when I ran into a little problem. The seat of bearing shells that I ordered came with 6 grooved shells and 4 ungrooved. I did some searching and found two contradictory threads.
5 & 5: http://forums.tdiclub.com/showthread.php?t=215516
This is a A3/B4 post though
6 & 4: http://forums.tdiclub.com/showthread.php?t=136058
Also something pre-ALH.
The Bentley Manual Says:
Bearing Shells 1, 2, 4, and 5
- For bearing caps without oil groove
- For engine block with oil groove
Bearing Shell 3
- Bearing Cap without oil groove
This seems to indicate its supposed to be 5 & 5. My engine does not have an oil groove on any of the bearing caps both engines that I have had 5 & 5.
So whats the final verdict? Should it be 5 & 5 or is something else going on?
Christian
There is also something about sizing the bearings, but the markings that are supposed to be on the block are not there.
Bearing Shell 3
Christian
