Magnetic Oil Pan Drain Plug Provides Inexpensive Way to Save Wear & Tear
Turbo Steve
Every TDI should have one of these inexpensive aftermarket plugs to help prevent tiny particles of ferrous metal and debris from being recirculated in your oil system.
Part #10.115.401K at only $3.50 each fits all TDI oil pans according to Autotech Sport Tuning. Size - M14 x 1.5
http://www.autotech.com/oilsys.htm#mdp
Telephone: (949) 240-4000
S
SkyPup
Guest
Definetly a good idea, too bad they weren't OEM. You can wrap you OEM steel plug with a wad of copper wire and hook it up to six volt battery for one hour to electromagnetically transform you stock plug into a magnetic one permanently too.
Ann
Midcoast Maine
2009 JSW
I see this in aviation. Folks will tape magnets to the outside of the oil filter for the same effect. (Obviously we are taking pistion engines here.)
1999 (A4) Jetta GL TDI
Atlantic Blue/Black
Ric Woodruff
BANNED, Ric went to Coventry.
Steve, that is what oil filters are for!!! And besides any LARGE shavings will sink right to the bottom of oil pan where they will remain.
Turbo Steve
Ric:
We're basically talking about the small tiny particles that are abrasive in nature. I guarantee you that even with a bypass filtration system, a magnetic drain plug will still have some particles adhearing to it each oil change - just like an automatic transmission oil pan's magnet will be covered with a thick abrasive substance.
Besides, this is only for positively charged optimists!
At $3.50, it seems that prevention is better than redemption!
Karl Roenick
Clifton Park, NY, US
Seems like a good idea to me. Aren't there other ways of magnetizing a piece of metal - eg, rubbing on another magnet? With the filter method, you just take off the magnets and throw away the filter, I guess. This wouldn't work with our drop-in cartridges though.
As an aside, if you want to put in an oil temp sending unit, you don't have to use the drain plug - there's apparently a plug that screws out of the oil filter base.
Yellow 2000 Beetle
valois
Banned
Karl, anything that realign the electrons will magnatize ferrous metals. You can temporarily magnetize a screwdriver by tapping it with another object. A degausing coil ($30.00) works well. It will Magnetize or demag, plugs into 110, it's a large coil near the size of a toilet seat, with a switch on the cord. You can make one with some copper wire and electrical tape. My favorite use is demagging agitated customers who would come in on the full moon when I was tending bar. It seemed to work! They aught to keep them in emergency rooms.
Don't take life too serious, don't take yourself too serious, and others even less serious,seriously!
98 jetta TDI
Peter Cheuk
Gasser :P
Daly City, Calif., USA
'06 Jetta GLI
I used to take apart old computer hard drives (especially those really large, physically, ones) and the magnets they used to drive the head assembly were really something. If you got two of them stuck together, good luck getting them apart. I am going to take another one apart and will place the magnets on my oil filter.
TwoSlick
Dixie
2002 Audi TT Roadster, 1990 Audi 100
The OEM Audi drain plugs have the magnetic insert ...you can buy one at any Audi dealer for less than $10.00. It does pick up all the tiny bits of ferrous materials - I have one on my 1990 Audi 100, 2.3L 5 cylinder. It has the same 19 mm hex head on the plug ....
Turbo Steve
BUG*PWR:
Right! Perhaps I should have even asked for his permission prior to starting this thread!
TwoSlick
Dixie
BUG PWR,
These are the same guy, with a new name ....
TS
colinstone
Oxford, England
On my old TR4A I had a large loudspeaker magnet on the sump underside. At oil drain time, I used to take off the magnet and all the little snurgles would run out with the oil.
MY2000 UK Golf IV GT TDI 110 bhp plus Tuning Box. Canyon Red/Beige
leather. All the toys.
MY2000 VW Lupo 1.4S
