robnitro
I used to have a Magnaflow 93006D 2.5" cat (the wider one, 7"). It got plugged up quick- when I saw that a straight pipe gave me less smoke/better boost response I did some research. Some other people have noticed that it clogs up and back-pressure goes up a lot (up to 9 psi!).
So, I rushed into bashing the ceramic matrix out, removed both and put the cat back on.
It started to be annoying to have the smell, especially idling in traffic. So, I saw a later thread that said he removed only 1 of the 2" thick matrices.... and back pressure was much less- and still it got rid of the stink. IMHO, the stock cat never gave me problems, and I believe because it was only ONE element in there... not 2.
So, I found one pretty cheap on the forum, but the narrower one, 94006D 2.5" (which has a body size of 6.5" instead of 7") and removed a matrix. It has been working great so far. The gutted 93006D cat is available, but I may use it as a "muffler" LOL.
FYI, to remove one matrix without breaking the other, get a long drill bit, and drill slowly until you feel it get way easy. STOP (you have about 3 inches to the next one that you don't want to break!). Repeat, make a couple of evenly spaced holes. Then be careful and use the drill bit to crack the element into pieces. Turn it upside down and it will fall out.
