MAF question (correct or not correct)
Airliner
Audi A4 1.9TDi Avant Quattro 2001 silver
I¨'m looking at group 003 on engine module on my 2001 Audi A4 1.9TDi PD. It says "Engine speed", "MAF specified", "MAF actual" and "EGR duty cycle".
When the engine is idling, the MAF specified is indicating 250 and MAF actual is aorund 250 (230 to 255 or something). BUT, when the engine has been idling for 3-5 min. the MAF actual is increasing to about 450, but the MAF specified is still showing 250. If I push the throttle and release it again the MAF actual goes back to around 250. But after 3-5 min it increases again to around 450.
Is this correct or not ?
jaydhall
Aurora Colorado
2012 Passat SE, 1999 NB, 1999.5 Jetta GLS, 2004 Jetta
I believe you are seeing the EGR affect the MAF reading.
The only way to really test a MAF is to do a run while loging 3 and MAP measuring block. It is on either this site or Ross-tech site.
Airliner
Ok.
Yep, I have seen the "MAF test" where you give full throttle from 1500-2000 rpm to 3500 rpm and log MAF vs rpm.
But I have a little problem: I have used Excel alot, BUT never to make a grahp from some numbers. So if anyone could post a little step by step list on how to make a grahp in excel after I have logged the nubmers, that would be great.
Cheshire Cat
the county Palatine of Chester
ibiza.130/skoda Octy4x4
I belive that the EGR valve is switched every two minutes on idling hence the variation in fresh air flow, you will see this on a vag scope especially if you block off the egr line and let it idle the signal will go to each extreme and give a square graph line
jaydhall
Aurora Colorado
Open the log file in excel. Mark what you would like to graph. (Select the numbers.) Use the chart wizard to graph them. Quite easy.
Airliner
Hmmm, the problem is:
1. Every numbers is in the same column (in this format ,0.31,903,250.0,235.2,53.4,,,,,,,,,,)
2. I cant figure out what chart to use when i want RPM to be one axis, and MAF to be the other axis. I can only figure out how to let RPM be one line, and MAF to be another line on the chart.
Uwe
Lansdale, PA, USA
If you're using a non-english version of Excel, use CSVConv.exe first.
If you want to plot something as a function of RPM, use an "XY (Scatter)" type graph.
-Uwe-
Airliner
Thanx. I have a english version of excel, but when I run CSVConv.exe the file formatted perfectly.
I even managed to make a chart with RPM on one (bottom) axis and MAF actual on the other (vertical) axis !
Uwe
Lansdale, PA, USA
Non english version of Windows? It's possible even an english version of Excel will assume it should accomodate whatever the Windows defaults are.
-Uwe-
Airliner
I have a norwegian version of windows since the shop didn't have the english version left when I bought the computer.
Uwe
Lansdale, PA, USA
Well, I don't speak Norwegian. The difficulties usually happen in langauges which use commas instead of periods as decimal seperators. If Excel thinks you have that, then it will not handle the standard "Comma Seperated Values" file format correctly, and that's why we have the CSVConvert utility..:)
-Uwe-
