milktree
- Joined
- Apr 8, 2011
- Location
- Eastern Massachusetts
- TDI
- 2015 Golf Sportwagen, 2004 Jetta Wagon (sold!)
The other day my check engine light came on, and this is what VAG-COMM reported:
http://wiki.ross-tech.com/wiki/index.php/16485/P0101/000257
How much "after" is "after"?
For instance, I noticed that the tube from the intercooler to the thingamajig (intake manifold?) was loose and crooked, like it had been put in wrong:
http://mahonkin.com/~milktree/tdi/crooked_pipe.jpg
I removed and properly (I think) fastened the hose, but it's still kinda loose: (but not crooked)
http://mahonkin.com/~milktree/tdi/loose_pipe.mov
Could this have caused the error?
Chassis Type: 1J (9M - VW Jetta IV (1998 > 2014))
Scan: 01 02 03 08 09 15 16 17 19 22 29 35 36 37 39 46 47 55 56 57
75 76
VIN: WVWSR61J14W0xxxxx Mileage: 365850km-227328miles
Address 01: Engine Labels: 038-906-016-BEW.lbl
Part No SW: 038 997 016 L HW: 028 101 114 6
Component: R4 1,9L EDC G000SG 1386
Revision: 12345678 Serial number: VWZ7Z0C8360182
Coding: 0150031
Shop #: WSC 01052 444 51243
VCID: 27432E879584937ADD-515A
1 Fault Found:
16485 - Mass Air Flow Sensor (G70)
P0101 - 000 - Implausible Signal
Freeze Frame:
RPM: 1533 /min
Torque: 0.0 Nm
Speed: 54.0 km/h
Temperature: 12.6°C
(no units): 100.8
(no units): 0.86
Temperature: 88.2°C
Readiness: 1 1 0 0 0
Reading around suggests that "Air Leak(s) after Mass Air Flow Sensor (G70)" is a possible cause. Scan: 01 02 03 08 09 15 16 17 19 22 29 35 36 37 39 46 47 55 56 57
75 76
Coding: 0150031
1 Fault Found:
Freeze Frame:
RPM: 1533 /min
Torque: 0.0 Nm
Speed: 54.0 km/h
Temperature: 12.6°C
(no units): 100.8
(no units): 0.86
Temperature: 88.2°C
