celry
I was able to get it to 5000 earlier this evening, no problem with a cool engine in neutral. Thanks!
Blip the accel pedal. If the car has been indling for more than a minute or two, the EGR will close, thus showing the actual reading at 485. If you blip the accel pedal, the EGR opens again and the actual MAF reading goes down (because air is bypassing the MAF and going into the intake through the EGR). Any time the actual is bigger than the requested, thats a good thing. Its when the actual readings are lower than the requested that you need to worry about changing it out. And as the previous poster mentioned, the test has to be done under load. A bad MAF might not show itself under normal driving conditions. You need to tget the requested up to 800mg/r and see what the actual is reading to determine if you need a MAF or not.BioBob said:I hooked up my Vag-com yesterday, and did an engine test.
The only odd thing I saw was this:
MAF spec 270 --- MAF Act 485.
After reading MAF101, I am concluding that I am getting too much air-flow.
Am I on the right track here, and is this a problem?
Thanking you in advance.
Bob
VAG-COM doesn't lie -- you need a new MAF sensor.KKennedy said:Does this mean the MAF is dead?
Should I even try to clean it since I've so many miles?
I don't know what to make of the self correction after I get it going down a hill.
That's because you went to limp mode. if you get the error again after erasing it, try cleaning the MAF and try again. I gotten this error once, deleted it and never came back.G60ING said:I had a sudden loss of power and the car revved like my G60 Corrado when the cat was clogged. slow to rev. The tdi would boost no higher the 12-14 psi and very slowly. So I figured a MAF. After scanning the car when I found a code for implausible signal for the MAF after arriving home. Has anybody else gotten this? I plan o confirm the reading by unplugging the MAF to see if performance improves.
Someone I know had some of this in their 'box of goodies' in the trunk... $5 a can... I think that is what you call marketing... it's a $2.50 can of starter fluid...MikeS_18 said:
Clearing the code did NOTHING. Spraying contact cleaner did NOTHING.Dimitri16V said:That's because you went to limp mode. if you get the error again after erasing it, try cleaning the MAF and try again. I gotten this error once, deleted it and never came back.
bam_bam_dip said:The first romp goes well over 4000 rpm, then as is wants to upshift........limp mode. The second romp was in limp mode.
