tomo366
TDI Lifer, Member #68
US diesel fuel is the worst fuel in the world....
Rick,I have a 2011 jetta SW with the DSG transmission and I do not use any fuel additives.
Dealer told me you do not need them?
I thought the clean diesel had all the additives in it you need (summer blend and winter blend).
Rick
"Clean diesel" does not pertain to the fuel. Our 2009+ TDIs are "clean diesel" cars because of their extensive emissions control systems. All US fuel is now "Ultra Low Sulfur Diesel" (ULSD), but this does not mean "clean diesel". It has less sulfur, so it is "cleaner" than older high sulfur fuel, but American diesel (ULSD) does not have to meet the same lubricity specifications as Canadian and European fuels. Bosch (a German company) designed our HPFPs based on European fuel standards. This is why many members here have decided that US diesel fuel needs some help in the lubricity (lubricating ability) department. VW does not advocate additives for 2 main reasons. 1) they do not want to admit that their cars require additives, and 2) They do not want to test hundreds of available additives and choose one (or more) to endorse. They also do not want owners to use "bad" additives - there are some of these around also. Do a search here for "lubricity + additive" and you will find several lengthy threads discussing many different additives and their individual pluses and minuses.I thought the clean diesel had all the additives in it you need (summer blend and winter blend)
Rick
Your dealer told you that because that's what they have to tell you. With a 2011 car, you likely have a HPFP with 2 of the 3 pump updates and you MAY not have as much to worry about as people with older pumps. Do some reading on injector/fuel pump lifespans with 520 um rated fuel in the U.S. vs. pump life with fuel rated in the 400's like the rest of the civilized world has. (These are wear scar numbers. Lower numbers are better). It ain't pretty. Unless you're running a biodiesel blend, add some approved lubricant to your fuel in the recommended doses.I do not use any fuel additives. dealer told me you do not need them? I thought the clean diesel had all the additives in it you need (summer blend and winter blend)
Rick
Can someone tell me since I am new to TDI's and still learning...I bought some Optilube XPD, and since then also found that the newest Enmark station sells diesel labeled as 2-5% (B2-B5) biodiesel. First, is Enmark an ok brand to use? Second, am I going to hurt anything by using the small mixture of bio AND the XPD??Not for lubricity, B1-B2 offers much better HFRR scores.
Nope. Simply cut the XPD dose back to the minimum recommended if you are using Bio.Second, am I going to hurt anything by using the small mixture of bio AND the XPD??
GM says not to use an additive, but if you want to use one, only use one that is recommended by them.I'll admit I don't know much about VW diesels in particular. But on the Chevy, Ford, & Dodge truck diesel forums its common knowledge not to use additives on newer diesel trucks because it ruins the injectors and shortens the life of the DPF filter. Injectors are almost $800 each x 8 injectors + labor = big money. DPFs run us 2-3K parts on the trucks. I will say its probably more important to make sure your fuel pump doesn't grenade leaving metal parts in the injectors. None of the trucks are having recurring problems with fuel pumps going bad. Seems like a VW quality issue with their pumps.
