frugality
Doing my 180k-mile oil change, I had difficulty getting the secondary hood latch to release. Turns out the hook on the left was binding on its pivot, and the plastic lever was flexing. I used a little spray silicone lube that I use on my door hinges.
If you've got an older Mk5 or Mk5.5, you may want to hit the hood latch with a little lube as a preventative measure. Never had an issue with my Mk4's latch.
