Redneckeric
As the title states the im replacing the control arms on my 03 jetta. Went to put the new arm in and the captured nut had broke loose. Cut a hole and had it welded. Went to reinstall arm and now the nut is physically stripped. Got to about 40 ft/lbs and the bolt goes from righty tighty to righty loosey. Obviously i need to cut the hole again but what size is the nut and should i get a nylock nut?
