JackBak
- Joined
- May 9, 2000
- Location
- Boulder, Colorado, USA
For all those who would like to do this read on...
OK, here it is instructions for removing the infamous snow screen on a
2000 NB TDI.
Time: Allow about 3 hours from start to finish.
Tools: Long Handled #1 Philips Screwdriver (may not need)
Channel Pliers
10mm Wrench
10mm socket with extension
Torx T-25 bit
Short screwdriver type holder for T-25
Regular length screwdriver holder for T-25
Tire Iron (17mm socket)
(Possibly) anti-theft adapter for wheel lug bolt
Procedure:
- Remove Left front wheel/tire (driver's side in USA). Use
Jack stand(s) and block rear wheels, etc. Take proper safety
precautions.
- Remove exposed wheel well skirt. Use regular length
screwdriver holder with T-25 driver for 13 screws, the 14th
and last T-25 screw will need the short handle as it is just
to the right of the suspension spring.
- Under the front bumper you will now see a "U" shaped
assembly. Bear with me as I describe this assembly and then
you will see how I call it a "U" shape. Assume you are
sitting facing the wheel well with the disc brake at about
stomach level. Now if you look directly up into the wheel
well at about the 11 or 12 o'clock position you will see a
black hard plastic pipe about 2.5 inches (64mm) in diameter
with a flared end to it. This is the end of one of the "U"
assembly's arms. It is the air intake before it enters the
snow screen box. Follow this tube down to find a box-like
black plastic assembly. This is the box that contains the
snow screen and is at the bottom of the "U". Note that on
its side is a spring loaded door that opens into the
box. The other arm of the "U" is just barely visable from
your vantage point, but this is the tube that will become
the input to the filter box in the engine compartment.
- Remove the 10mm nut holding the snow screen box brace to the
body. Now remove a 10mm hex head screw that holds the flared
air intake tube to the body. At this point the air intake
arm and the snow screen filter box may be wiggled loose from
the other arm of the "U" going up to the air filter box in
- At this point I went top-side into the engine compartment
and removed the air filter box, disconnecting the MAF sensor
plug, etc. BUT in hindsight I don't think that is really
neccesary.
- I was not able to get the flared tube and snow screen box
(they are clamped together with a short piece of rubber
tubing with two compressable tubing clamps - thus the
channel pliers in my tool list) out without removing a
fender support brace. If you can get at one of those tube
clamps you could separate the flared air intake tube from the
snow screen box, but I couldn't and had to remove this short
3 inch (76mm) brace - two T-25 screws.
- Now that the snow screen box is out and in your hands you
can look down into the box and see the screen. It looks like
fine nylon panty hose. You can now also see how when this
screen gets totally crudded up the spring loaded door in the
side of the box will open due to air pressure and totally
by-pass this snow screen. What a .... design.
- By carefully prying the top of the snow screen box off its
base the snow screen itself may be lifted out and cleaned or
thrown away (I chose the latter). In 1500 miles of spring
driving my screen was 33% clogged with dust and weed fuzz
that my K&N filter could easily have trapped if it actually
made it all the way up there.
That's it. Assemble in reverse order. Remember this description applies
to a 2000 New Beetle TDI.
Enjoy.
-Jack
2000 NB TDI.
Channel Pliers
10mm Wrench
Torx T-25 bit
Procedure:
precautions.
neccesary.
Enjoy.
-Jack
