genscripter
I have 0.75 volts at my fuel solenoid shutoff. I checked over all my fuses and they have connectivity.
I traced my wiring back to the barrel connector, which is also putting out 0.75 v.
Do you think this might be a relay issue? I doubt the FSS has a relay for something requiring such low current. Could this be the ignition switch (i doubt it due to the fact that all the other electronics seems to work fine)?
I can jump my FSS with a 12V wire from the battery and the vehicle starts and runs fine. Currently with 0.75V, I'm unable to get the FSS to click when touching connector, nor does the vehicle start (no fuel getting to the injectors, as expected with no power to the FSS).
