Been running MAX PSI for 20+ years. Get best fuel economy and car just rolls better, in my experience!I also respectfully have to say that the pressure on the tire is max psi, not the recommended pressure for your car. Don't run max psi. Well, I guess you can if you want to, but I certainly wouldn't.
It is certainly true that your fuel economy will be slightly better due to running tires that are hard due to being inflated at maximum pressure.Been running MAX PSI for 20+ years. Get best fuel economy and car just rolls better, in my experience!
1 Fault Found:
01325 - Control Module for Tire Pressure Monitoring (J502)
005 - No or Incorrect Basic Setting / Adaptation
Freeze Frame:
Fault Status: 01100101
Fault Priority: 3
Fault Frequency: 1
Reset counter: 255
Mileage: 146322 km
Time Indication: 0
Date: 2008.14.05
Time: 19:58:45
Hmm, this looks like it just might work. I remember going into the long coding helper and it shows all 0s like you describe. But I didn't mess with it.I had that happen too. You can fix it with VCDS. This is from my post, #126 in this thread. If you poke around like I did, maybe you can find the same place to reset the controller.
From post #126
"I found that the controller coding had reset to all zeros! I went into the long coding helper and found that the 3 different bits could be changed from no coding 00, to the proper coding of 01, 87, and 05, to end up with 018705 as in my original scan. That still didn't clear the issue, not immediately, but after I drove and restarted the car the fault finally disappeared!"
Code with error, reset to 018705 fixed my issue!
Address 65: Tire Pressure (J502) Labels: 1K0-937-08x-65.clb
Part No SW: 1K0 937 087 G HW: 1K0 937 087 G
Component: RDK 103 0521
Coding: 000000
Shop #: WSC 131071 1023 2097151
VCID: 354FC35B9C8DCAB6775-8060
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 255
Mileage: 124497 km
Time Indication: 0
Date: 2041.14.30
Time: 18:55:30
I don't know if I have the original scans. I'm using a new computer (Dell Venue 11) and those scans would be on the previous netbook I was using before. But that computer has been having some issues.^^Good luck! Mine has been fine for more than 2 years since I fixed the coding for the controller. I hope it works for you too. I guess you should also check your original scan to use your numbers, not mine. Although maybe mine would work fine. Maybe they're even the same numbers.
Again, good luck!
Ok, I managed to locate an original scan and my code was 018704. The long coding helper shows the last bit is 05 for Factory mode and 04 is a service mode. Setting it to 05 didn't work. Error remained. But when I set it to 04, it cleared. Fault went away without me even going in and doing it myself.I searched and found the link below with a a full scan from a different 2010 MKVI TDI. The car had the same numbers for the controller!
See post #46 at this link
from Post #46 at link
Address 65: Tire Pressure (J502) Labels: None
Coding: 018705
Shop #: WSC 01357 011 00200
No fault code found.
You need to do that AFTER you check all the tires.DOn't know if anyone mentioned this because I'm too lazy to look, but I just picked up a 2012 tdi Sportswagen today and the low tire pressure light came on. Called dealer and he told me about the reset switch located in the upper left of the glove compartment. Press and hold for 5 seconds and it resets and recalibrates the TPMS.
Haha. I did that.You need to do that AFTER you check all the tires.
Oh snap! That'll do itHaha. I did that.
Light came back. Checked. All good. Reset.
Light came back. ***?! Oh well. Kept driving.
Couple tanks of fuel later, noticed something like I had a bent rim.
Nope. Cords and belts separating.
It was just enough to upset tire rotation.
It looked a lot better with air pressure. Haha.
Oh snap! That'll do it![]()
Sent from my s-off'ed m7 with CM11
11-05-13 Post #126Sure enough, in my car the setting had changed to 5.5 bar! Funny, or not so funny really, that the thing resets itself to such a high pressure. Hopefully it won't happen again for at least another 2-years. I guess I really do need my own VCDS for this VW.
04-09-14 Post #135It's been a little over a year since the last time, but it happened again! Well, kind of. The TPMS came on again and when I checked my tires they were all exactly what I set them to not too long ago. They were holding pressure great!
So, since now I finally have my own VCDS, I went in to check things for myself. I figured it reset to 55 again. Nope! They were all still at 22, just like they were when my wonderful friend set them lower for me last year. I also couldn't clear the fault and the measuirng blocks didn't seem to work. I was confused, but kept poking around.
I found that the controller coding had actually reset to all zeros! I went into the long coding helper and found that the 3 different bits could be changed from no coding 00, to the proper coding of 01, 87, and 05, to end up with 018705 as in my original scan. That still didn't clear the issue, not immediately, but after I drove and restarted the car the fault finally disappeared!...
12-06-19It happened to me again! TPMS light on and all tires OK. This is the third time for me in 4 years. This time the controller had reset to 55 as explained in previous posts. Thanks to VCDS I'm fault free again!
cool story bruhlast post was Oct 2021. lol
