tdihopeful
Was prompted to or considered checking oil and fill of coolants knowing that I was probably past due on that. Found oil was under acceptable low limit. Thought it better to add whatever oil than nothin. Only gas stations were open this morning and no deisel specific oil available. I added a quart of 10w 30 I think it was and a little oil additive. I probably should oil change. Rotella T perhaps... I took note that there is oil seepage from the valve cover gasket area. The valve cover was made in China while my car was built in Germany. I expect to see VW/AUDI parts that are manufactured in Mexico but seeing the cover seemed an aftermarket part being significantly shinier in appearance is a little suspect for perhaps timing belt failure and valve damages perhaps at sometime. Maybe this is indicative of what caused a shaking at speed around 80. Could timing belt failure and perhaps valve damage cause a change of engine rotational mass balance to be a little off?
