X CELL TDI
Hello, my car is a 2002 ALH wagon, had the car sitting for about 4 years and been doing all the maintenance to start driving it again, I'm having an issue with code p0245, I've replaced the n75, the turbo actuator, checked for vacuum leaks and all is good, I can hear the turbo whine, no smoke at all, engine runs smooth no vibrations, I have full rev range and can get to 80+ mph if flat, lose speed going uphill, so I guess it's not in limp mode, just no building enough boost specially on load, scangauge boost shows no more than 5psi, the wiring to n75 looks good, connector looks good, is there something else that I'm missing? Read that it might be ECU related but that often comes with other codes not just P0245, please let me know what to look for I've reading old threads but haven't found any answer to my situation any help will be appreciated thanks in advance.
