Looking TDI Mechanic
Baine
Springfield MO
2005 TDI Passat
Not sure if this is the exact thread to use but give it a shot. I recently moved to the Lake of The Ozarks in Missouri. Larger towns around are Camdenton, Osage Beach and Versailles along with many other smaller communities. Does anyone know of a TDI specialist in this area or is there a place on this forum to search. I have found one in Sedalia mo, about 1 hour away, doable, but wanted to see of possibly one closer. Thanks!!
DonL
Kingman, Arizona
2005 Jetta wagon
You are lucky to have found a guru only an hour away. My choices are two hours away and 3.5 hours away. I took it over 1,000 miles for the 200k timing belt change, but I also had business up there.
