Looking for guru in MTL
Rafbrittain
Montreal
Passat 2005 tdi
Hi guys, just wondering if anybody knows any tdi gurus around MTL that I could take my 2005 Passat tdi gls to.
I developed a leak from the transmission and it's been acting up lately, the garage I go to told me to come back next week to fix the leak ... They filled it up for now but I'm scared that even with the leak fixed I'll still get some slippage as it's still doing it a bit, or maybe i'm paranoid...
Looking for a second opinion.
Thanks!
TDIGAZ
Eastern Ontario, Canada
Current: 2003 Jetta GLS Grey 5 spd. Previous: 2003 Jetta GLS Silver 5 spd (lost in a collision)
.... any tdi gurus around MTL that I could take my 2005 Passat tdi gls to...
Not sure how how far you mean by "around Montreal" but there's an excellent VW guru just outside Cornwall. Username "Volkswheels" on here, and his shop is called Volkswheels Mechanical, contact info can be found online.
I take my Jetta to him for any major repairs.
Good Luck with your transmission.
Rafbrittain
Montreal
Passat 2005 tdi
I will definitely check his shop out, it's a little far for me but for good quality work it doesn't really matter. Thanks TDIGAZ !
tigman
Mont St-Gregoire
jetta 99.5 -780,000kms + jetta 2001 220000kms aut
South shore of Montréal
Garage Automotion
900 simard
Chambly J3L 4X2
Téléphone (450) 447-6677
specialize in volks/audi
snakeye
Montreal, Canada
2003 Jetta and Wagon, GLS 5sp
Garage Laramee in ste anne des plaines knows their volks and then aren't very expensive. They work fast, though, so it's worth double checking the minor things to make sure nothing is missing.
makita
Joliette
Jetta 1.9 TD 1992, Jetta Variant 1.9 TDI 2003, Golf Variant 1.8 TSI 2016
If you have troubles with your transmission (the infamous ZF 5HP19), you should go to TransMart on Francis-Hughes, Laval.
He's actually the guy that rebuild and do the warranty work on transmissions for the local VW dealer... but not at dealer rate...
Radman
Montreal
2014 Audi A6 TDI, 2014 Touareg TDI
The "ZF" Transmission specialist here in Montreal is: http://www.eurowa.com/
How many KMS on the tranny? Mine failed at around 250K which is the lifespan of an Auto trans. Mine went into limp mode (stuck in 3rd gear) and would not shift anymore when it died. If your tranny is failing expect to spend easily 2 to 3k. Likely more than the value of the car...
Jlaasf
Ontario
2003 Jetta Wagon TDI
I've used Matt for a lot of my work the last couple years. Absolutely recommend him!
