Looking for 10k+ Mile Used TDI Engine Oil
camerons17
Nashville, TN
Volkswagen 4-cylinder, 1.9L TDI diesel engine
Hello,
I am in search of used Shell Rotella T6 5W-40 motor oil, preferably with around 10k+ miles of use put on it using a VW TDI Engine. An owner who has done his/her own oil change would be ideal but not necessary. This oil will be used to test oil quality sensing technologies for university research purposes.
Please reach out if you have a sample of 3.5L or more; we are willing to compensate to an agreeable amount. My apologies if I've broken any site-wide rules with this post; I'm unfamiliar with this forum.
Edit: We also are looking for 10k mile used Ravenol HPS 5W-30 semi-synthetic. Please reach out if you have any information.
Thunder Chicken
Sioux Lookout, Ontario
2012 Golf Wagon
I’m not quite ready for an oil change, but will be in a month or so. I’m running a 2.0 TDI If that matters. (Without a dpf or egr) I’d be happy to save it for you.
JDSwan87
Black Swamp Thing
Michigan near Toledo
2001 Jetta TDI, 5 speed Lagoon Blue Metallic(sold); 2005 Jetta TDI Wagon auto
Does it have to be T6? I'll have 5 quarts of Schaeffer's OTR Plus with 10k miles on it coming out in a few weeks...
_ian
Franklin TN
'14 Touareg LUX, '14 JSW
Hello,
I use T6 in my '14 Touareg and '14 JSW. I'm happy to give you the used oil but it might be a while since I changed both recently.
camerons17
Nashville, TN
That would be great! If you send me another message a couple weeks or so before you change the oil, I'll let you know if we are still needing oils. Thanks for you reply.
camerons17
Nashville, TN
I’ll have probably about 11qts (4 from PD 1.9 at 11k and 7+ from Cayenne TD 5k change on this one ) soon.
We would he happy to have both of these, separately. If you let me know when you do the oil change we can coordinate shipping/compensation. Thanks for your response!
Mozambiquer
Versailles Missouri
Ok, you've piqued my curiosity... What is the project?
camerons17
Nashville, TN
Given the results of the last university study done on TDI's, I'm wondering what they're up to, too.:unsure:
Hi,
We have developed a controlled oil testing facility in which we use an oil quality sensor (along with temperature, pressure, and flow rate measurements) to analyze the quality of different used or new oil samples. The goal is to use these oil quality measurements along with other flow parameters like viscosity, vibration, etc. to investigate new methods of real-time engine health monitoring.
The reason we are specifically looking for TDI-run oils is because we also have access to a TDI testbed engine that we use in tandem with the controlled facility to verify results.
