So I just went through the "re-establish grounds" routine.... the hard way. Didn't realize until part way through that it really IS necessary to completely remove the airbox first, but I got there.
After getting the air box out of the way, then it was removing the battery tray. Of the 4 bolts holding it in, the two 10mm wrench-size bolts on the fenderwell side were really rusted up and I thought I'd snap them off, but they eventually came out. The other two, on the engine side, were really clean and no problem. Oh -- and don't forget, another bolt & nut to remove for the Frost Heater I'd installed....
Once I got the battery tray out, however, I discovered there was the main battery negative-to-frame bolt, and then two more terminals, each of which had two wires with ring terminals connected to 2 additional ground studs.
Cleaned them all up and re-assembled the whole shebang. Ground connections weren't bad, per se, but I was able to get them cleaner than they were. Added dielectric grease, copper-based anti-seize on the rusted bolts (after wire-brushing them with a Dremel), and put it all back together. We'll see how much of a difference that makes with the long-crank situation. Can't hurt!
