Tdimrtwo
I have a 2010 JSW with a locked up engine and a “good” 88k mile CJAA engine that I plan to swap out soon. I also want to do the CP4 to CP3 hpfp swap to avoid the CP4 metal shavings nightmare that I’ve read and heard so much about.
1. Would it be better/easier to do the CP3 swap on the new engines before I install it, or is it just as easy with the engine installed?
2. I’ve read that you both need a tune and don’t need a tune to make it run well with the CP3 swap (without a cel). Whitbread’s website says a tune is needed, so what is the best/least expensive tune for fuel economy and driveability, not really looking for power gains.
3. What kind of vehicle can be a donor for a used CP3 hpfp? Whitbread lists two compatible Bosch part numbers, but doesn’t say what the pumps were used on. I believe I’d rather source my own local HPFP than get the rebuilt one from England that whitbread sells. I understand that CP3 pumps were at least used on BMW’s and domestic pickups, but I don’t know if all CP3’s are the same.
Any info or advice on what I may be missing would be greatly appreciated.
