Fix_Until_Broke
This started out as an idea quite a while ago from a discussion with Jfettig, but over the last few months, I was able to make it into a reality - Having the ability to monitor engine power on a vehicle, real time, anytime, anywhere. Chassis dyno's are good, but a real pain to take time to do, schedule, etc and they're also relatively expensive if you're doing part/tuning comparisons.
Ok, so how do we do this and not spend big $$ on wheel hub torque sensors or telemery on strain gauges put on the axles or flywheel, etc like the OEM's do? We need torque and speed to calculate power. Given the engine mounting layout on the MKiV chassis, if you remove the dogbone mount, the engine/transmission rotates freely on the two upper mounts. If we could put something in the dogbone that would measure force, then if we know the distance between the upper motor mounts and the dogbone (thanks A5INKY !), we can calculate torque.
Enter in a load pin, used for all kinds of force measuring things, made by a bunch of different companies. Perfect for this kind of application.
So, I took an old dogbone that I had, bought some clevis's and such from McMaster, spent some time on a lathe making everything fit with the OEM bushings and chassis interface and came up with this replacement dogbone assembly that measures force.
Here it is installed in my car. It's been there for a few months now, seems to be holding up fine. No additional noises/vibrations/etc (not that my car is a good reference for that kind of thing).
Ok, so now we have force and with a bit of math we have torque. This torque is not engine torque though since it's reacting the entire driveline through the transmission and final drive. Fortunately, this is all just more math through the transmission ratios to get back to engine torque.
Engine speed is relatively easy - just a sensor on the flywheel (same as I used for my cranking compression tests).
So, after all this, we've got force, engine speed, a bunch of math and then ultimately power. I've got a fancy data acquisition system that does all of this, but it's not required - a very inexpensive 2 channel (1 analog, 1 digital) system would do the same thing, you'd just have to post-process the data in Excel or Matlab or whatever tools you're comfortable with.
So I hooked all this up, and took it out for a test drive and got the below results from a 5th gear pull. I'm not sure how much I trust the absolute values (they seem low to me), but the ability to evaluate changes is more important than the actual numbers anyway.
And for those of you in the metric system - one in NM and Kw
Because pictures are a little boring, here's a video of how the data goes across the screen in one of the configurations
http://youtu.be/46I9IizjiVk
There's still a lot more to do to make it easier to use, more accurate, etc, but I'm pretty happy with it and see a lot of value to come from it as well.
Thanks for reading
Thanks for reading
