IwishTDI
- Joined
- Sep 10, 2008
- Location
- Pittsburgh
I'd be up for a GTG in the spring. Gotta get a new cam before then hopefully.
Hey everyone, need some guru thoughts here. I scanned this car; it is a 2002 with 96k miles. All service was performed at the dealer before the purchase and the new owner believes the TB was done there at 60k. The intake has also been cleaned.IwishTDI said:When PA had those few nights of bitter cold my car went inside the garage. Anyone in the Pittsburgh area have Vag-com that isn't on the list? I really need to get my timing checked.
Get this ride to Growler's STAT....Stirer said:All service was performed at the dealer before the purchase and the new owner believes the TB was done there at 60k.....The car is only getting about 30 mpg
at idle do you hear any noises that sound like a small tack hammer hitting cast aluminum? tak tak tak tak etcIwishTDI said:The shortest trip I take is usually 18-20 Miles, going to Butler or Ellwood. It might just be the winter fuel, but I'm always running 8oz of PowerService if it makes any difference. Could you be more specific on what noise I'm listening for?
With a 2002, you really ought to get your cam/lifters looked at for abnormal wear.IwishTDI said:The ticking under Acceleration still has me worried. It does it in Park too, it's just not as loud.
Out of curiosity, how many miles you have on that?IwishTDI said:The ticking under Acceleration still has me worried. It does it in Park too, it's just not as loud.
Dave, I may take you up on that. I live in Cranberry by North Boundary Rd. I still have about 7 K miles left before I need an oil change.pghPAtdi said:Beer caps make that noise when i drink while working on my Tdi and toss then into the engine bay.
Delphi: I've got a Pella if you would like to give it a go for changing your oil.
Dave
Fixed your message there. yes, removing the cam does make it so all the valves are closed at once. upon reassembly, you really wanna make sure that the cam is in the correct position and or the crank is turned 45 degrees to guarantee that the valve cannot hit the pistons. this way you can get the cam in and locked down before you go to line the crank back up to get it back in time. if you don't understand how to do this, you might want to ask for help at this stage or get the car to someone who can re-time it safely.PitPassat said:Thanks Aaron for getting back so quickly. I will try to clean it out with the head on then. I suppose the removal of the CAM is to prevent any valve from being open so no gunk can go inside.
How about any buildup on the valve stems? I have seen pictures of heads that came off that had all the intake valves with a good amount of buildup on the stems. Does this clean out itself over time or might this be reason for considering washing the head.
On another tune: Is there anybody in the area who has the TB tools and could lease them for a weekend?
Thanks,
Wolfgang
WVU TDI said:Has anyone dealt with the VW dealership in Canonsburg? I'm getting ready to finish up my master's program and should have a good job coming out of school, would like to swap my '01 (sell it to my dad) for a new Sportwagen TDI. Thought I might ride up that way this weekend and see what they've got, but I'd rather not even pull on the lot if they've got a crappy reputation.
WVU TDI said:Sounds good, I won't be ready to buy until June, but I'm a big fan of planning ahead. Would like to maybe try out an '09, with the stick of course, and see if it's really what I'm after.
