List of Reported problems on Xenforo test site: August 2020
VW Derf
Administrator
Richmond, BC, Canada
2010 Blue Graphite Pearl Golf Variant
As noted in this thread regarding the test TDIClub site, please note any problems you noted with respect to the test forums found here: https://xenforo.tdiclub.com.
If the issues are sensitive in nature, please email me or send me a PM.
Thanks,
Nero Morg
OR
Was able to post scaled photos, when trying to post unscaled via a link, got the following error.
VW Derf
Administrator
To confirm what you were testing, you are linking an image from imgur and the first embedding worked, but the second, larger file did not.
Nero Morg
OR
That is exactly correct.
VW Derf
Administrator
Ok, I've confirmed that issue and will find a solution. It is resolution related, however items in the new media gallery seem to work fine.
VW Derf
Administrator
Right off the bat something I noticed is on mobile, there's no "go to last page" straight from the forum index. Have to open the thread then click last page.
Noted. I'll see what options are available to add this to the mobile view.
BobnOH
not-a-mechanic
central Ohio
New Beetle 2003 manual
One of the forums I use, https://www.diychatroom.com/forum.php, uses a routine to automatically resize posted images to fit screen. It does however sometimes rotate them as well. Believe they use VerticalScope sauce ware.
Took the new site for a quick spin, seems you're pretty far along!
thanks
