SevilleSharan
- Joined
- Feb 4, 2002
- Location
- spain
I have a sharan minivan with about 110KKm (66K).
Since it was 20K it has sporadically lost about half its power output when accelerating uphill.
The dealer first changed the fuel cut-off valve (no change).
-ECU (no change)
-Turbo (OK for about 20K)
-ECU (OK for 5K. Probably just luck)
The dealer always shows a printout from the 1551 with no codes.
Now the problem is back. As I am tired of the dealer not fixing the problem (and not changing the N75 and the lines that go into/out of it) I decided to study the problem myself and bought a VAG-COM and the injection system repair (includes the turbo) from VW Erwin.
When I read the engine log I got:
1 DTCs Found:
00575 - Intake Manifold Pressure
17-00 - Control Difference
According to the manual:
-N75 or lines or Turbo
The output test looks OK but this does not realy mean that there is not an sporadic N75 or turbo lock.
I decided to monitor the MAP preassure and try to produce the failure while logging data. Yesterday I was lucky and got the data while the car went into limp mode and in http://icaro.eii.us.es/~civit/noturbo.htm you can find the data for 2 minutes before the failure and about 1 minute after. When the car goes into limp mode the N75 control output is almost 100% and the turbo produces no boost (SDI like mode).
It can be seen that either the N75 or the turbo gets locked producing a boost pressure of about 2500Mbar and, thus the ECU decides to cut off the turbo to safe the turbo and the engine.
What do you think?
I have been trying to convince the dealer to change the N75 for a long time but they will always tell me that is OK. This van is much more difficult to self service than passats or golfs as the engine area is much more compact.
-ECU (no change)
1 DTCs Found:
What do you think?
