HiMost common and easiest to fix is a leak in the charge air circuit (turbo outlet to anti-shudder valve). Next most common is a leak in the vacuum signal that goes to the turbo vane actuator. Mine is a BHW, so a little different from yours, so I can't tell you where all to look.
I'd check and see if you have good vacuum. Should be 28in/hg (not sure the metric equivalent and I'm too lazy to Google that right now )Hi
and thanks for your help I’ve checked all the pipes for any leaks I haven’t found any all seems to be fine
