OnePutt
- Joined
- May 21, 2007
- Location
- The burbs of NorCal
- TDI
- 2001 Golf (Silver) | 2005 Jetta Wagon (Spice Red)
Limp mode issue (sorry...another one)
2005 Jetta Wagon
I bought it w/ an AFE CAI (which I would like to replace w/ a PD150 TIP...but besides the point). RC2 tune, VNT17, EJ SMIC. I needed to pass SMOG so I put a stock air box on and on my way to the station, my car went into Limp Mode, CEL on, car drives like crap. Anyhow, I took it back home and reinstalled the CAI (cleared the codes) and the car hasn't been the same since.
Now my car continually goes into limp mode and I can hear a loud swooshing noise on throttle. I've swapped out the MAF w/ a known good unit and I have the same problem. I've also looked at the MAF sensor wiring in the conduit and don't see any breaks in the wire, but it's tough to really tell. Car runs no differently if the MAF is connected or not.
Here are the codes from VAG-COM:
Address 01: Engine Labels: 038-906-016-BEW.lbl
Part No SW: 038 997 016 L HW: 028 101 181 2
Component: RC s02f EDC G000AG 3791
Revision: 12345678 Serial number: VWZ7Z0D0127737
Coding: 0150034
Shop #: WSC 00000 785 00200
VCID: 27530A3E95F6351
3 Faults Found:
16683 - Boost Pressure Regulation
P0299 - 000 - Control Range Not Reached
Freeze Frame:
RPM: 2520 /min
Torque: 232.0 Nm
Speed: 45.0 km/h
Load: 63.5 %
Voltage: 14.44 V
Bin. Bits: 00001100
Absolute Pres.: 2325.6 mbar
Absolute Pres.: 1897.2 mbar
16502 - Engine Coolant Temp. Sensor (G62)
P0118 - 000 - Signal too High
Freeze Frame:
RPM: 882 /min
Torque: 24.0 Nm
Speed: 40.0 km/h
Load: 0.0 %
Voltage: 14.14 V
Bin. Bits: 00001100
Temperature: 52.2°C
Temperature: 61.2°C
16486 - Mass Air Flow Sensor (G70)
P0102 - 000 - Signal too Low
Freeze Frame:
RPM: 1134 /min
Torque: 20.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Duty Cycle: 100.6 %
Bin. Bits: 00001111
Mass Air / Rev.: 935.0 mg/str
Mass Air / Rev.: 0.0 mg/str
Readiness: 1 1 0 0 1
Any ideas?
2005 Jetta Wagon
Coding: 0150034
3 Faults Found:
Freeze Frame:
RPM: 2520 /min
Torque: 232.0 Nm
Speed: 45.0 km/h
Load: 63.5 %
Voltage: 14.44 V
Bin. Bits: 00001100
Freeze Frame:
RPM: 882 /min
Torque: 24.0 Nm
Speed: 40.0 km/h
Load: 0.0 %
Voltage: 14.14 V
Bin. Bits: 00001100
Temperature: 52.2°C
Temperature: 61.2°C
Freeze Frame:
RPM: 1134 /min
Torque: 20.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Duty Cycle: 100.6 %
Bin. Bits: 00001111
Any ideas?
