Limp mode and Check Engine Audi A6 C6 2006 2.7tdi
Ivelin109
Bulgaria
Hello. I've been struggling with my Audi for the past month. It first started close to a month ago when i started my car in the middle of the day and it sounded a lot more different than it did. The sound from the exhaust pipes was 3x louder, when i got off the parking lot it didn't go over 1300-1500rpm. Hardly going over 30-40km/h. Then i realised it was coming from my AC, whenever i turn off the ac it returns to it's normal sound and no longer has limp mode. Since then i never turned the AC on, 3 weeks later today. I turned it on without AC and the sound came back and so did the limp mode... I restarted the car 10x only once it wasn't limp. My VCDS scan is there as well from today. Hours later now check engine showed up, i drove like this for a month and now it came on? What would be the problem. In my opinion is Compressor but i never turned that AC on.
Thursday,05,September,2024,01:00:43:00009
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 11 x64
VCDS Version: 23.11.0.0 (x64)
Data version: 20231027 DS351.0
www.Ross-Tech.com
VIN: WAUZZZ4F27N087846 License Plate:
Chassis Type: 4F (4F0)
Scan: 01 02 03 05 07 08 09 0E 15 16 17 19 42 46 47 4F 52 53 56 61
62 72 76
VIN: WAUZZZ4F27N087846 Mileage: 330450km-205332miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
07-Control Head -- Status: Malfunction 0010
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
0E-Media Player 1 -- Status: OK 0000
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: Malfunction 0010
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: Malfunction 0010
53-Parking Brake -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
61-Battery Regul. -- Status: Malfunction 0010
62-Door, Rear Left -- Status: Malfunction 0010
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: OK 0000
Address 01: Engine Labels: 059-907-401-BPP.clb
Part No SW: 4F1 910 401 R HW: 4F0 907 401 C
Component: 2.7L V6TDI G000CG 0030
Revision: --H03--- Serial number:
Coding: 0011382
Shop #: WSC 66565 257 00032
VCID: 2C57B1B78F0B3EF14F-8078
VINID: 9D196AAAA11608778020720418E9C07260
6 Faults Found:
004118 - Valve for Air Filter Bypass Flap (N275)
P1016 - 001 - Open Circuit
Freeze Frame:
Fault Status: 01100001
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Temperature: 54.9°C
Temperature: 28.8°C
(no units): 0.0
(no units): 0.0
049921 - Software Incompatibility with Engine Control Module
U0301 - 003 - - MIL ON
Freeze Frame:
Fault Status: 11110011
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 322168 km
Time Indication: 0
Date: 2023.08.31
Time: 21:59:34
Freeze Frame:
RPM: 1197 /min
Torque: 89.7 Nm
Speed: 32.5 km/h
Duty Cycle: 11.0 %
Voltage: 13.68 V
Bin. Bits: 00101000
Torque: 249.6 Nm
005663 - Glowplug for Cylinder 6 (Q15)
P161F - 001 - Open Circuit
Freeze Frame:
Fault Status: 01110001
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 326351 km
Time Indication: 0
Date: 2024.05.11
Time: 14:22:40
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Duty Cycle: 1.0 %
Voltage: 11.55 V
Duty Cycle: 15.0 %
Temperature: 16.2°C
005504 - Throttle Actuator (Bank 1)
P1580 - 008 - Malfunction
Freeze Frame:
Fault Status: 01111000
Fault Priority: 0
Fault Frequency: 22
Reset counter: 255
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Voltage: 12.84 V
Duty Cycle: 0.4 %
012867 - Control Circuit for Throttle Body Module
P3243 - 004 - Electrical Malfunction
Freeze Frame:
Fault Status: 01100100
Fault Priority: 0
Fault Frequency: 11
Reset counter: 255
Mileage: 330164 km
Time Indication: 0
Date: 2024.08.02
Time: 16:41:00
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Voltage: 12.46 V
Duty Cycle: 0.4 %
Duty Cycle: 0.4 %
005716 - Please check DTC Memory of Instrument Cluster
P1654 - 005 - - Intermittent
Freeze Frame:
Fault Status: 00100101
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 330425 km
Time Indication: 0
Date: 2024.08.31
Time: 08:55:23
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Duty Cycle: 1.0 %
Voltage: 12.08 V
Bin. Bits: 00101000
Torque: 70.2 Nm
Readiness: 1 1 0 0 0
Address 02: Auto Trans Labels: 01J-927-156.lbl
Part No SW: 4F2 910 155 D HW: 01J 927 156 JG
Component: V30 0AN 2.7lTDI RdW 0010
Revision: --H03--- Serial number: 00000000000414
Coding: 0000001
Shop #: WSC 02325 785 00200
VCID: 25414493ECE10FB990-8070
No fault code found.
Address 03: ABS Brakes Labels: 4F0-910-517.clb
Part No SW: 4F0 910 517 AC HW: 4F0 614 517 T
Component: ESP8 front H01 0070
Revision: 00000000 Serial number: 00000000000000
Coding: 0020872
VCID: 65C10493AC61CFB950-8030
Address 05: Acc/Start Auth. Labels:. 4F0-910-852.clb
Part No SW: 4F0 910 852 HW: 4F0 905 852 B
Component: FBSAUDIC6 ELV H31 0220
Revision: 31050601 Serial number: 10601100599951
Coding: 0000131
Shop #: WSC 02323 785 00200
VCID: 63C51A8BA255B189BE-8036
Subsystem 1 - Part No: 4F0 910 131 E
Component: FBSAUDIC6 EZS H45 0080
Subsystem 2 - Part No: 4F0 910 220 D
Component: FBSAUDIC6 IDG H01 0040
Address 07: Control Head Labels: 4F0-910-7xx-07-H.clb
Part No SW: 4F1 910 732 D HW: 4E0 035 729
Component: Interfacebox H43 5570
Revision: 00000000 Serial number: 350K$067737747
Coding: 0001005
Shop #: WSC 02335 785 00200
Subsystem 1 - Part No: 4F0 910 609 E
Component: Bedienteil MMIC6H01 0060
Subsystem 2 - Serial number: 00000000590898
Subsystem 3 - Serial number: 0122.11.060000000100010681ÿ
Subsystem 4 - Serial number: 010681ÿ
3 Faults Found:
01325 - Control Module for Tire Pressure Monitoring (J502)
004 - No Signal/Communication
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 189
Mileage: 326652 km
Time Indication: 0
Date: 2006.05.10
Time: 20:00:30
01319 - Control Module for Distance Control (J428)
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 189
Mileage: 326652 km
Time Indication: 0
Date: 2006.05.10
Time: 20:01:01
01964 - Control Module for Seat & Steering Column Memory (J136)
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 189
Mileage: 326652 km
Time Indication: 0
Date: 2006.05.10
Time: 20:01:01
Address 08: Auto HVAC Labels: 4F0-910-043.clb
Part No SW: 4F0 910 043 A HW: 4F1 820 043 AF
Component: KLIMABETAETIGUNGH30 0020
Revision: 00000052 Serial number: 00000030180466
Coding: 0000278
VCID: 1C376177DFABCE713F-8048
Address 09: Cent. Elect. Labels: 4F0-910-279.lbl
Part No SW: 4F0 910 279 K HW: 4F0 907 279
Component: ILM Fahrer H17 0240
Revision: 00000000 Serial number: 4F0907279
Coding: 0010101
VCID: 3169A0C3A82953197C-8064
Subsystem 1 - Part No: 4F1 910 113 C Labels: 1KX-955-119.CLB
Component: Wischer AudiC6 H05 0210
Coding: 00064784
Shop #: WSC 02335
Subsystem 2 - Part No: 4E0 910 557 A Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH13 0090
Coding: 00146221
Shop #: WSC 02335
2 Faults Found:
00978 - Lamp for Low Beam; Left (M29)
010 - Open or Short to Plus - Intermittent
Freeze Frame:
Fault Status: 00101010
Fault Priority: 2
Fault Frequency: 254
Reset counter: 104
Mileage: 262136 km
Time Indication: 0
Date: 2024.05.24
Time: 15:56:00
00979 - Lamp for Low Beam; Right (M31)
Freeze Frame:
Fault Priority: 2
Reset counter: 104
Mileage: 262136 km
Time Indication: 0
Date: 2024.05.24
Time: 15:56:00
Address 0E: Media Player 1 Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 110 E HW: 4E0 035 110 A
Component: MP3-Changer H44 0390
Revision: 00044000 Serial number: AUZ5ZBF3117300
Shop #: WSC 00000 000 00000
VCID: 1A3B676FD59FB0412D-804E
Address 15: Airbags Labels: 4F0-910-655-8R.clb
Part No SW: 4F0 910 655 E HW: 4F0 959 655 B
Component: 42 AIRBAG AUDI8RH29 0280
Revision: 08H29000 Serial number: 0037LD0HT3GN
Coding: 0013362
VCID: 295948A380F92BD9B4-807C
Subsystem 1 - Serial number: 6332CSME14633D1B3
Subsystem 2 - Serial number: 6342CSME15213D41Z
Subsystem 3 - Serial number: 6352QSME1A423C31D
Subsystem 4 - Serial number: 6362QSME19721A23D
Subsystem 5 - Serial number: 63734SME19261D0D3
Subsystem 6 - Serial number: 63834SME1A081053U
3 Faults Found:
00532 - Supply Voltage B+
002 - Lower Limit Exceeded - Intermittent - MIL ON
01317 - Control Module in Instrument Cluster (J285)
004 - No Signal/Communication - Intermittent - MIL ON
02095 - Component Protection Active
000 - - - Intermittent - MIL ON
Address 16: Steering wheel Labels: 4F0-910-549.lbl
Part No SW: 4F0 910 549 HW: 4F0 953 549 A
Component: Lenksäulenmodul H08 0230
Revision: 00H08000 Serial number: 90026063220585
Coding: 0002042
VCID: 66C3039F5167C4A159-8032
Subsystem 1 - Part No: XXXXXXXXXXX
Component: Lenkradmodul H07 0090
Address 17: Instruments Labels: 4F0-910-xxx-17.lbl
Part No SW: 4F0 910 900 C HW: 4F0 920 901 C
Component: KOMBIINSTR. M73 H12 0120
Revision: 00400000 Serial number: 58U703AC6
Coding: 2304148
Shop #: WSC 80093 222 69422
VCID: 204F5587F3C3EA91E3-8074
1 Fault Found:
00771 - Fuel Level Sensor (G)
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 98
Mileage: 330424 km
Time Indication: 0
Date: 2024.08.31
Time: 00:15:47
Address 19: CAN Gateway Labels:. 4F0-910-468.clb
Part No SW: 4F0 910 468 A HW: 4F0 907 468 D
Component: Gateway H11 0070
Revision: 11 Serial number: 1300806B1980A6
Coding: ECFE53C41B0104
Shop #: WSC 02334 785 00200
VCID: 275D4E9B96ED1DA9A2-8072
Address 42: Door Elect, Driver Labels: 4F0-910-793-42.lbl
Part No SW: 4F0 910 793 E HW: 4F0 959 793 E
Component: TSG FA H12 0120
Revision: 00-00000
Coding: 0001642
Shop #: WSC 02327 785 00200
1 Fault Found:
02115 - Locking Unit for Central Locking
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 3
Reset counter: 104
Mileage: 326648 km
Time Indication: 0
Date: 2006.05.10
Time: 12:44:05
Address 46: Central Conv. Labels:. 4F0-910-289.lbl
Part No SW: 4F0 910 289 G HW: 4F0 907 289 G
Component: Komfortgeraet H22 0170
Revision: 01700022 Serial number: 01025253880000
Coding: 0008837
VCID: 2E53BBBFB9174CE161-807A
Address 47: Sound System (J525) Labels: Redir Fail!
Part No SW: 4F0 910 223 M HW: 4F0 035 223 N
Component: Amp.-ASK-RD H07 0270
Revision: 07S00000
Coding: 080001
Shop #: WSC 02399 823 56573
VCID: 285F4DA75BF312D1AB-807C
8 Faults Found:
00870 - Bass Speaker Front Left (R21)
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 5
Fault Frequency: 3
Reset counter: 104
Mileage: 269234 km
Time Indication: 0
Date: 2019.02.14
Time: 16:09:01
Freeze Frame:
Voltage: 13.60 V
Temperature: 8.0°C
Bin. Bits: 00000111
00420 - Front Right DSP Midrange Speaker (R104)
Freeze Frame:
Fault Priority: 5
Fault Frequency: 3
Reset counter: 102
Mileage: 269234 km
Time Indication: 0
Date: 2019.02.14
Time: 16:09:01
Freeze Frame:
Voltage: 13.60 V
Temperature: 8.0°C
Bin. Bits: 00000111
00871 - Bass Speaker Front Right (R23)
Freeze Frame:
Fault Priority: 5
Fault Frequency: 3
Reset counter: 102
Mileage: 269234 km
Time Indication: 0
Date: 2019.02.14
Time: 16:09:01
Freeze Frame:
Voltage: 13.60 V
Temperature: 8.0°C
Bin. Bits: 00000111
00419 - Left Front DSP Midrange Speaker (R103)
Freeze Frame:
Fault Priority: 5
Fault Frequency: 3
Reset counter: 102
Mileage: 269234 km
Time Indication: 0
Date: 2019.02.14
Time: 16:09:01
Freeze Frame:
Voltage: 13.60 V
Temperature: 8.0°C
Bin. Bits: 00000111
02558 - Rear Left Mid-Range/Woofer Loudspeaker (R159)
Freeze Frame:
Fault Priority: 5
Fault Frequency: 3
Reset counter: 102
Mileage: 269234 km
Time Indication: 0
Date: 2019.02.14
Time: 16:09:01
Freeze Frame:
Voltage: 14.00 V
Temperature: 8.0°C
Bin. Bits: 00000111
02559 - Rear Right Mid-Range/Woofer Loudspeaker (R160)
Freeze Frame:
Fault Priority: 5
Fault Frequency: 3
Reset counter: 102
Mileage: 269234 km
Time Indication: 0
Date: 2019.02.14
Time: 16:09:01
Freeze Frame:
Voltage: 14.00 V
Temperature: 8.0°C
Bin. Bits: 00000111
00446 - Function Limitation due to Under-Voltage
Freeze Frame:
Fault Status: 00100010
Fault Priority: 7
Fault Frequency: 4
Reset counter: 104
Mileage: 309244 km
Time Indication: 0
Date: 2022.12.23
Time: 10:19:16
Freeze Frame:
Voltage: 8.70 V
Temperature: 0.0°C
Bin. Bits: 00000010
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 104
Mileage: 278780 km
Time Indication: 0
Date: 2021.03.28
Time: 11:42:36
Freeze Frame:
Voltage: 6.70 V
Temperature: 10.0°C
Bin. Bits: 00000111
Bin. Bits: 00000101
Bin. Bits: 00000000
Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl
Part No SW: 4F0 910 280 HW: 4F0 907 280
Component: ILM Beifahrer H10 0080
Revision: Serial number: 00000000200659
Coding: 0001003
VCID: 5EB32B7F89379C6191-800A
Address 52: Door Elect, Pass. Labels: 4F0-910-793-52.lbl
Part No SW: 4F0 910 793 E HW: 4F0 959 792 E
Component: TSG BF H12 0120
Revision: 00-00000
Coding: 0001770
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Reset counter: 64
Mileage: 326648 km
Time Indication: 0
Date: 2006.05.10
Time: 12:43:44
Address 53: Parking Brake Labels: 4F0-910-801.clb
Part No SW: 4F0 910 801 C HW: 4F0 907 801 A
Component: EPB CDEC0080 H04 0080
Revision: --H04---
Coding: 0000531
Shop #: WSC 02324 785 00200
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 T HW: 4F0 035 541 H
Component: TUNER EU/US/RDW H42 0630
Revision: 00000000 Serial number: 394KW067706601
Coding: 0000001
2 Faults Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 6
Reset counter: 104
Mileage: 280484 km
Time Indication: 0
Date: 2021.08.29
Time: 00:57:54
Freeze Frame:
Fault Priority: 7
Fault Frequency: 124
Reset counter: 104
Mileage: 269234 km
Time Indication: 0
Date: 2019.02.14
Time: 15:33:06
Address 61: Battery Regul. Labels: 4F0-910-181.clb
Part No SW: 4F0 910 181 E HW: 4F0 915 181 A
Component: J0644 BEM H12 0590
Revision: 00000000 Serial number: 00000000151498
Shop #: WSC 02335 823 00000
VCID: 23455A8BE2D5F189FE-8076
Subsystem 1 - Part No: 4F0 915 105 D
Component: von VA0 2611161393
Coding: 344630393135313035442056413032363131313631333933
Shop #: WSC 00000 384 00290
4 Faults Found:
02274 - Quiescent Current Stage 3
Freeze Frame:
Fault Status: 00100000
Fault Priority: 7
Fault Frequency: 31
Reset counter: 255
Mileage: 280484 km
Time Indication: 0
Date: 2021.08.28
Time: 23:01:47
02277 - Quiescent Current Stage 6
Freeze Frame:
Fault Priority: 7
Fault Frequency: 21
Reset counter: 255
Mileage: 280484 km
Time Indication: 0
Date: 2021.09.01
Time: 13:18:43
02272 - Quiescent Current Stage 1
Freeze Frame:
Fault Priority: 7
Fault Frequency: 109
Reset counter: 255
Mileage: 284353 km
Time Indication: 0
Date: 2021.10.06
Time: 12:05:25
02276 - Quiescent Current Stage 5
Freeze Frame:
Fault Priority: 7
Fault Frequency: 4
Reset counter: 255
Mileage: 323961 km
Time Indication: 0
Date: 2006.06.02
Time: 04:23:46
Address 62: Door, Rear Left Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 E HW: 4F0 959 795 E
Component: TSG HL H21 0050
Coding: 0001066
1 Fault Found:
Freeze Frame:
Fault Status: 01101000
Fault Priority: 3
Fault Frequency: 68
Reset counter: 62
Mileage: 326648 km
Time Indication: 0
Date: 2006.05.10
Time: 12:47:48
Address 72: Door, Rear Right Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 E HW: 4F0 959 794 E
Component: TSG HR H21 0050
Coding: 0001066
Address 76: Park Assist Labels: 4Fx-910-283.lbl
Part No SW: 4F0 910 283 F HW: 4F0 919 283 F
Component: Parkhilfe 4-Kan H09 0060
Revision: 00H09000 Serial number: 06230631500938
Coding: 0201016
Shop #: WSC 131071 1023 2097151
End-------------------------(Elapsed Time: 02:19)--------------------------
STDOUBT
Portland, effing Oregon
dos jettas
Welcome to TDI Club!
That's a considerable list of faults. Probably the most telling are these:
6 Faults Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Time Indication: 0
Freeze Frame:
Fault Priority: 0
Fault Frequency: 22
Reset counter: 255
Time Indication: 0
Freeze Frame:
Fault Priority: 0
Fault Frequency: 11
Reset counter: 255
Mileage: 330164 km
Time Indication: 0
Date: 2024.08.02
Time: 16:41:00
I would start by checking all the grounds in your car. Make sure they're clean and tight. Then try clearing codes and running it.
Also, here is our canonical Limp mode thread. Much of the contents could apply to your car. Getting under your car and verifying all the boost pipes are well connected wouldn't hurt either.
Ivelin109
Bulgaria
Thanks for the reply! Now that i second-checked the error you pointed out, i saw it today, but i thought it was days before it happened, but i was wrong. This error that ill show was on 08.02.2024, i saw videos of my car when the loud noise occured, it was exactly that time 16:40 AND same exact day. So this error is the cause. ------
Freeze Frame:
Fault Priority: 0
Fault Frequency: 22
Reset counter: 255
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Voltage: 12.84 V
Duty Cycle: 0.4 %
Freeze Frame:
Fault Priority: 0
Fault Frequency: 11
Reset counter: 255
Mileage: 330164 km
Time Indication: 0
Date: 2024.08.02
Time: 16:41:00
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Voltage: 12.46 V
Duty Cycle: 0.4 %
Duty Cycle: 0.4 %
