I noticed that the climate control cluster below the radio does not light up anymore with the rest of the IP. I heard there was a bulb that controls that. Does anyone know how to access and replace that bulb??
The hose isn't necessary, I just used some tissues and a regular set needle nose pliers to remove and install the new bulb, a small vise grip with a towel did the trick to get the knob off. Thanks again!
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
