Light Bar For Jetta
WolfgangVW
Alberta, Canada
2003 Jetta TDI - Manual
Hey all, I know I have beat the light thing to death over the years but any new ideas or setups for a light bar on a MK4 Jetta!!????
Blacktree
Central FL
'02 Jetta 5-spd
I second that recommendation. I put one of his light bars on my Jetta. It's great!
Maybe you can send him a PM and see if he still makes them.
Dh4276
South Carolina
2006 Golf GLS TDI, BEW
I put a bar in the lower grill and works great. Have it set up to come on with high beams.
Dh4276
South Carolina
Nice one! What size / kind of bar did you buy??
I’ll have to double check but I believe it was a 26” bar. Got it off amazon. It’s mounted to the bumper cover which is great since it does not have to be removed to take the cover off should you have to. I cut the sender grille just enough to clear the light while keeping the remaining grille on either side of it.
It was a 22”, it’s also a curved bar which has the perfect arch and matches the curve of the bumper.
Mongler98
COLORADO (SE of Denver)
Proper headlights with projectors and cutoffs. HIDs
Done
GlowBugTDI
Cambridge, MN
Millenium falcon still makes the light bars. You can find them under the for sale and wanted section of the Forum
Sent from my SAMSUNG-SM-G890A using Tapatalk
WolfgangVW
Alberta, Canada
Awesome thanks! Looks good!!
ItAintRodKnock
Fraggle Rock, CO
01GolfTDi
I run a Nilight 22" 270w Triple row LED light bar.(Amazon) I absolutely love the thing.
I had TWO 9.5" LEDs (pictured)in the same spot before, but wanted more light for "Herping."
Ran through a relay to a switch inside the cab next to the Emergency Flashers button.
For the 22" i had to build a bracket to lower it so that it was centered(height off ground) in the bumper opening.
Sent from my VS987 using Tapatalk
WolfgangVW
Alberta, Canada
Nice! Did you upgrade your headlights at all?
WolfgangVW
Alberta, Canada
So how exactly did you guys wire up the lightbar etc?? As far as wiring , switches , relays go etc?? Just purchased one on amazon hope to install soon!!!
WolfgangVW
Alberta, Canada
Negative. Completely stock(for a jetta), running H7? Light bulbs i think.
The lens are crystal clear after a wipe down with blue magic lens restorer.
ah ok cool. Ya I found the ecodes were a big improvement, just my lenses are cracked and fogged now ..... maybe ill try to restore them...
Dh4276
South Carolina
I ran a switch to the blank wheee the seat heater switch goes in the center of the dash. Since mine was primarily for use on dark backroads looking for dear, I tapped off the high beam for my signal to the relay mounted in the engine compartment on the firewall.
When I hit the high beams, I now have a wall of bright led light for about 150-160 degrees in front of me. I got the curved bar which helps with the angle.
06 Golf 5MT, BEW, Kerma tune, Catectomy, Bypass oil filter system
WolfgangVW
Alberta, Canada
^^ Nice! So with the high beams and the switch the light bar comes on, but without the switch just high beams??
Dh4276
South Carolina
That’s correct, technically it’s illegal, but since I always dim my high beams when I see a car coming it doesn’t really matter.
